well slacker69 and i went to drive his car today and the nitrous only worked like twice...Whats the problem? OK when we press the WOT switch it sprays both the nitrous and the fuel..both tbe solenoids click..the arming switch is new and it is on..BUT when we go to drive the car and go to WOT it does not spray anything..its like it wont work when the motor is actually on?
the throttle is not hitting the wot switch you have to mount it in the right place and firm so when you are at wot it hits the switch i am pretty sure that is the prob.
1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
yea i had the same problem. the wot switch has to be perfectly lined up with the throttle body. so it will activate when you mash the gas
97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
The WOT switch is on the floor under the pedal cause my car is not a cable driven throttle body and it is hitting the switch when u go WOT it is just not activating
Check the wires on there. The other thing is that you have a FPSS running. If that activates do to improper fule pressure it will shut down. Remember th tests last night.
94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
Well it works if we test it I may go get some more gas. You dont think I went throught a bottle last night. I used a 35 shot 3 or 4 times and a 50 shot like 3 times
First weigh the bottle to see how much you have in there.
The wot is on the gas pedal? Make sure the carpet or mat are not affecting it.
Also fuel psi?
