what causes nitrous backfire - FirebirdV6.com/CamaroV6.com Message Board
  • what causes nitrous backfire
    Seeing mins post scares me now. What cause it to do that. And can it be prevented. I have a nx kit and FPSS and window rpm switch, and WOT switch. And bottle warmer and purge so what else do i need to buy in order to not blow up my lid lol.
    Low rpm activation.
    Remember our intake manifolds are not designed for wet nitrous kits. With wet kits you could possibly get puddling of fuel in the intake manifold. This then could become the perfect home for a nice ball of fire and boom, backfire.
    95-97 v6 f bodies seem to need the maf screen. W/o it you can seem to get a bog. If you juice large shots (say 120 for example) you will have nice backfires :D
    How can you prevent it?
    3000 rpm's and above
    Direct port wet kit
      So since I have a MSD window RPM switch that activates at 3000 rpms and cuts at 5900 rpms I should worry to much and im only runnig a 100 shot at the most only at the track and a 75 shot on the street I will be ok right
        There is never a 100% guarentee with nitrous.
        You are running a wet kit on a manifold not intended to have fuel in it.
        I'm about to do the same.
          what if u port and polish the intake
            i dont think port & polishing the intake would help any, your still putting fuel thru a intake which isnt designed for one. i dont really know what happened with my kit, i was over 3k rpm's and the gas was floored when i hit it. and i am also running double the shot of nitrous you are :D
            -min
            [ March 03, 2002: Message edited by: Min ]</p>
            <b>Mods :</b><br />NX Nitrous Kit 125 shot<br />Walboro 255 In Tank Fuel Pump <br />Whisper Lid<br />K & N Filter<br />BMR STB<br />BMR SFC\'s<br />Comp Cams Camshaft<br />Port\\polished heads & intake<br />CIA Headers<br />3 Inch Cat<br />Transgo Shift Kit<br />Corvette Servo<br />180° Stat<br />Flowmaster w/ quad tips
