Hey guys, I have the NX kit. My nitrous filter is slightly leaking. When I pop the hood I can hear the nitrous filter leaking out on the end where it connects to the Sylonoid. I cant seem to get it to seal. Any tricks? Is it dangerous to be using the nitrous while it is leaking? It is a very very slight leak. You cant see it you can only hear it. what should I do?
NITROUS FILTER
did you put some teflon paste on the threads before screwing it on?
-min<b>Mods :</b><br />NX Nitrous Kit 125 shot<br />Walboro 255 In Tank Fuel Pump <br />Whisper Lid<br />K & N Filter<br />BMR STB<br />BMR SFC\'s<br />Comp Cams Camshaft<br />Port\\polished heads & intake<br />CIA Headers<br />3 Inch Cat<br />Transgo Shift Kit<br />Corvette Servo<br />180° Stat<br />Flowmaster w/ quad tips
i dont think its dangerous, but if you let it leak, your nitrous will slowly leak out<b>Mods :</b><br />NX Nitrous Kit 125 shot<br />Walboro 255 In Tank Fuel Pump <br />Whisper Lid<br />K & N Filter<br />BMR STB<br />BMR SFC\'s<br />Comp Cams Camshaft<br />Port\\polished heads & intake<br />CIA Headers<br />3 Inch Cat<br />Transgo Shift Kit<br />Corvette Servo<br />180° Stat<br />Flowmaster w/ quad tips
Teflon paste, not the tape.
Is it safe, I guess so.
If it leaks then you will never be able to hold pressure.
Also if you are leaking nitrous then your car may always run rich cause the fuel is not leaking.
Get the leak fixedRace car - gone but not forgotten - 1997 firebird V6
