Mods before NOS? (basic questions) - FirebirdV6.com/CamaroV6.com Message Board
  • Mods before NOS? (basic questions)
    Well I've recently become interested in getting NOS mainly becaues it's relativley cheap. What I'm wondering is what everyone would say the minimum for mods "should" be before you decide to go with NOS. I have every free ram air mod I can find w/ a K&N. I also plan on getting new exhaust. But thats about it cause I just won't be able to make enough this summer and once I'm in college there's not gonna be any more mods, or few and inbetween. I know I don't have to have anything but what would be a good idea?
    A few other things. I found that I should get that book from barnes and noble. Does it tell you ALL of the dangers with NOS? Also should I go wet or dry? I'm leaning more towards safety but is wet more expensive? Is the ZEX kit actually safer or is it a marketing ploy? Are there any online sources that I could check out before I buy that book? Sorry about all the questions but I want to know everything before I decide. Thanks
    1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
    an msd dis 4 would help with lighting off the no2 mixture. spark plugs, and as many bolt on goodies as you can afford.
    2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
      I would recommend intake and a catback exhaust at the very min. I would get copper plugs and do an overall tune up.
      Do you know what the difference between wet and dry is? NOS Kit #5175 is a dry kit. It will just spray nitrous into your intake. It will increase your fuel pressure and use the existing fuel system. With a wet kit it will spray nitrous and fuel into the intake.
      I would recommend doing all the reading about systems before you make your choice.
      Good luck!
        Dude you're getting NAWWZZZZ!!! some people will argue against my comment that you can never fully prepare an engine for nitrous but the more reinforcements you have under the hood, the better luck you'll have with it. I've seen people invest quite a bit building up the engine for a shot of nitrous and they still end up frying the engine. Poor luck I guess. I'm in favor for nitrous, but I've always felt it is a 50/50 gamble. When I can set aside enough money for a rebuild after setting everything up, then I'll consider nitrous.
        12second..... you're crazy man!!! [img]graemlins/omg.gif[/img] [img]graemlins/thumbsup.gif[/img]
        1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
          OK first thing, NOS is a brand, nitrous is the stuff you are looking to get.
          Minimum stuff to do.... nothing at all w/ add on mods (technically)
          The kits are designed to work w/ the stock fuel/ ignition systems in all the vehicles.
          Ways to improve the system:
          Exhaust: start w/ cat back, high flow cat, then headers (or whatever order your budget can handle).
          Now you can get all that extra air out but what about getting it in??
          Intkae: lid, cold air, free mods etc
          Dangers of nitrous: grenade engine, melt a hole through a piston, hole in the block, basically engine go boom :(
          Our intake manifolds are designed for dry kits, wet really shouldn't be used. But there are some who do (including me soon).
          If you plan on staying under 85 hp then go with dry, anything over that then I suggest wet.
          Most common kits used
          NOS
          NX
          TNT
          Do a search for all the safety things that can be done for nitrous kits
            <blockquote>quote:</font><hr>Originally posted by 12secondv6:
            <hr></blockquote>
            no offense but .. he will be getting a lot of extra air in since he is goin to be utilizing nitrous..
            Focus more on exhaust upgrades Raven .. also..
            tune up..
            replace gas filter...&lt;-- most commonly overlooked.
            lighten your car up...gears... etc..
            [ March 24, 2002: Message edited by: xdamxincx ]</p>
            97\' RS camaro<br />406ci sbc <br />69\' SS camaro<br />383ci sbc
              true, headers, high flow cat, and cat back shoud be at the top of your list. maybe head and cam later to better utilize the no2. and adj. fpr will keep her from running lean. lsd will keep you from going through tires as fast unless you use the no2 only at higher speeds. a ta rear gear cover will keep your rear end cooler and help it last longer with all the tq/hp going back there.
                can you get away w/nitrous w/o changing headers.
                  <blockquote>quote:</font><hr>Originally posted by 99Camaro99:
                  can you get away w/nitrous w/o changing headers.<hr></blockquote>
                  you most certainly can ...
                    So it may be for the better if I install my headers and ram air hood before the N20 ?
                    2000 Firebird M5<br />Ghetto lid<br />Lost the air silencer, told the wife \"Gee honey, must of fallen off somewhere\"<br />K&N filter<br />Dynomax cat back<br />Tinted windows<p>In stock but not installed yet:<br />SLP ram air hood<br />RK Sport headers<p>\"You want how much for that . .?\"
                      Do you need headers, no
                      Will the set up preform better w/ full exhaust and intake yes.
                      Can you hold out on the nitrous or do you want it now?
                        Hmmm, thats an easy choice, of course I can wait for the Nitrous, the question is, can my wife?
                          i am selling the 5175 kit $400 shipped
                          Hot Cammed LT1 Sleeper
