Alright i sprayed nitrous on my car and it messed up really bad.....but ok heres my question to see if the MAF sensor is broken, if the condition of the motor doesnt change with it pluged in and unpluged does that mean that it is broken and could that cause my motor to have a miss fire?
Nitrous/MAF troubles
2000 Pontiac Firebird v6<br /><b>Whisper Air lid|Holley PowerShot Filter| Polished MAF/TB| FRA |Cut Hole In Hood |160 Thermostat| Flowmaster Exhaust| SLP Fan Controller| Auto light Plugs gapped at .045| Factory Option 3.42 gear LSD| Aluminum Drive shaft| Front Sway Bar Removed <br />No Back seats| No passanger Seat| No spare tire or jack</b><br />Just Added My Zex Kit<br />[I]1/8 9.384 @ 76.713 mph (N/A) 9.2@84.7 mph 2.3 60 foot(Nos)[/ITags: None
Well, the MAF when unplugged should cause the engine to get very erratic like a misfire, and probably won't start without it, or run terribly if you can get it started. However you could have also caused some serious engine damage if you were not careful....how big was the shot you used? Do you have any kinds of safety devices?96 camaro Y87 M5 Ram CAI flowmaster 160 stat b&m shifter 3.42\'s relocated air temp
I fried my MAF sensor on a backfire and was able to drive the car home on a 3 hr trip. If it wasn't for the leaky injectors it would have run smoother. If you unplug the MAF it will default into MAP mode. Car should still driveable. So you may have internal problems. It may be time for a compression test.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
