Um, That doesn't make sense from what I'm looking at under my hood. The vacuum I have coming off the intake doesn't even go the the FPR, it goes into some black thing then circles around the back of the engine then up the drivers side to a fuel line with a service port in it (green cap, tag says don't exceed 1psi max pressure)? (not exactly sure, the lines are hard to follow)
The vacuum line off the FPR is a 1/8" line that runs around the back of the engine and to a sensor of some sort towards the back of the intake manifold (passenger side), then it leaves that sensor and enters a large wire loom so I have no idea from there.
