Well - FirebirdV6.com/CamaroV6.com Message Board
Well
  • Well
    I have my bottle mounted. :D This weekend I will be doing the rest of the install.Just a couple questions, my purge only has one metal tube what would be the easiest way to have a dual purge.Could I get some small vac. line and tee it off?
    2000 Navy Blue Firebird <br />3.8 A4 Y87<br />Member of the MTFBA (Middle Tennessee F-Body Association)<br />Factory dual exhaust,Pontiac Decal on w/s Cutout,A/F Ratio & FP guages<br />K&N Filter Taylor Spiro-Pro plug wires and NGK TR6\'s<br />Whisper lid,NX Wet 50 shot<br />Hotchkis LCA\'s & Panhard,Michelin Pilot XGT Z4 245/50ZR16<br />SLP Strut Tower Brace<br />NA 1/4-15.132@89.29 2.194 60\'<br />N20 1/4-14.174@98.04 2.228 60\'<br />F-Body Gathering 5 Trophy Winner
    just use a tee it off
      You can find some more copper tubing at a hardware store. If you can't find the right size there (alot of times they don't carry tubing as small as you need) you will be able to find some at a hobby shop, thats where I got mine. You can use a brass block T to split it.
      Edit: Oh yeah, good luck with the install! [img]graemlins/burnout.gif[/img]
      [ October 03, 2002: Message edited by: 96BeastV6 ]</p>
      -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
        Coool!!!!!!
        OK, well get a t fitting, do not use vaccum line, copper tubing or braided line only.
        I have used plastic and rubber tubing and it eventually fails
          Thanks guys, I will see wait I can muster up.I will be posting up if there is anything else I come across.
          As I say that I remember.How do you guys see your pressure guages if you have them at the bottle?Any suggestions?
            I look over my right shoulder.
            Take a look in my sig
              Your bottle is right there.
                Well started install Friday.I have everything done now except the wide open throttle switch and the window switch.
                Does any know what cylinder cycle are cars are in for a window switch?I know the LS1's are in 4 cylinder mode.Also were is the RPM wire on our PCM?
                  <blockquote>quote:</font><hr>Originally posted by Barry:
                  <hr></blockquote>
                  Is that an MSD window switch? If it is, then see this thread. I'm still having no luck with this window switch working with the factory ignition.
                    No, I am going with the Harlan window switch.
                      Sorry man, I dunno about window switches.
                      Mines an auto and I don't bother.
                      Maybe the msd thread might shed some light hopefully
