Hey man did you put tubes in your ET streets I was all over www.ls1tech and some 10 sec cars and alomost all 11sec cars are not using them. I want good nitrous launches (now the post has to do with nitrous.) Also what psi do u run them at.
12secv6 need help
12secv6 need help
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
I run mickey thompson et streets 26 x 11.5 x 16's mounted on a salad shooter stock 16 x 8 rim
I run no inner tubes.
I only have about 4-7 passes on them.
None have ben successful due to either spinning or losing a tranny or fuel slenoid
I did get a dead hook to a 1.630 but lost the tranny and fuel solenoid
From my little experience I have found that 16 psi works well
Best of luck and hold on [img]smile.gif[/img]Race car - gone but not forgotten - 1997 firebird V6
