and what is a window switch.
with a fpss do you still use a wide open throttle switch
Yes u do. The WOT switch still an activation. It goes activation switch to WOT switch to FPSS and that then completes the circuit and u begin to spray.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Have you tried a search?
FPSS= fuel pressure safety switch
If the fuel pressure is met then this will allow the nitrous to flow due to the pressure allowing the electrical curcuit to be complete
WOT switch= wide open throttle switch
Once the throttle body blade is completely open it will hit the toggle portion of the WOT switch and this will allow the circuit to be met and nitrous can flow.
Window switch= this is something that allows the nitrous to flow within a predetermined rpm range (or window). You chose the start and stop rpm limit's via rpm 'pills'Race car - gone but not forgotten - 1997 firebird V6
