i just got my nitrous installed and last night i went and raced a gt. since my car is a auto was it ok that i sprayed through shifts. also after the install i kinda heard this knocking sound not really bad just kinda annoying is this the nozzle that is mounted in my intake that is causing this. and after i raced i smelt a funny smell coming from my car it wasnt a burning smell just a funk type smell. also what bottle psi should i be running at. does anyone have any bottle mounting tips on places besides my trunk where my ttops go. sorry so long
some questions about n2o
Ok I'll see what I can reply with!
On an auto it is just fine to spray through shifts.
The smell was probably the engine being cleaned out because nitrous does this pretty well.
the noise I have no idea you'll have to be more specific on that, is it ONLY when you are spraying or is it all the time since the install and where is it coming from/what does it sound like?
Lastly the spare tire compartment or on the hump/where the hump is are other popular mounting locations. IF you remove the back seats you can mount it on the floor!
For bottle mounting, check out the pictures in the link "My Car" in my sig.
The noise, hmmm, don't know about that. Like Nachius said, is it all the time or what?
Bottle psi, I only hold about 700 with no heater, which is too low. I hold 850 with the heater.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
well it has been ever since the install but we didnt get a chance to spray it yet because it rained in the town where i got it installed. its kinda like a clanking noise. like i said didnt do it before the shop installed the kit i am figuring it might be the intake since they drilled into it. see when i bought the kit it was for imports with fuel return system so they had to "modify" it its a dry kit but he tapped it into the intake is this ok. also if i get a bottle heater will it make the n2o hit harder.
Cody, call robert and make sure how he hooked it up. If it's dry, do not spray it! If the black line that goes towards the abck on the engine bay is or fuel, it's all good (wet kit). Bottle pressure is key in any good run!If you just kind of warm it, you'll get a good run or two, get it warm ALL THE WAY through the bottle, and it'll last.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
900-1050psi is where you want to be. Nitrous will flow at 800psi. Shouldn't have any problem getting that psi right now in this heat. Mine has been sitting over 900 psi for 3 weeks.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
I soak mine in the hottest water I can draw up for about an hour or so Cody...by the time I get to the track, it's usually about 1000psi, and it usually holds pretty steady there until the bottle runs low.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Spray through shifts in an auto is fine
Modify.... import kit.... care to explain?
As for the warm water bathe... that works in the summer, but not winter (jersey winter's at least)
Cranking, you need to pin point the location of it
[ May 22, 2003: Message edited by: 12secondv6 ]</p>Race car - gone but not forgotten - 1997 firebird V6
