I want to know how much is ok to spray with stock internals, i have intake exhaust, (will have gears) and maybe ported heads... so if i have ported heads and no other internal mods would i be ok to spray 100 or no, 100 is really what i am shooting for without dropping a rod or something of that nature.
how much to spray
how much to spray
Green 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX SystemTags: None
A 100 shot would do fine with stock internals. If it's a dry shot you might consider upgrading the fuel pump.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Is this for a 3.4 or 3.8?
3.4 a 100 shot may be a little much
3.8 should handle it ok
Either way if the car is in good running condition and you don't have any other problems you should be ok. Nitrous is known for making known problems worse! Just make sure you get enough fuel if its a Dry shot and go have fun!
Since you have a 97 RS I would go with the HP level intended by the nitrous manufacturers only!
Nitrous is not safe.
You CAN blow your motor on a 50 shot.
NOS kits come with an 85 hp dry shot
NX kits come with a 75 hp wet shotRace car - gone but not forgotten - 1997 firebird V6
<blockquote>quote:</font><hr>Originally posted by 12secondv6:
NX kits come with a 75 hp wet shot<hr></blockquote>
Whats that supposed to mean, (Since you have a 97 RS) i know you can blow your engine with N20 you can mess up your engine with lotsa things, i was just wondering if i could do 100 shot without messing up my internals?
[ June 03, 2003: Message edited by: foshizl ]</p>Green 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX System
<blockquote>quote:</font><hr>Originally posted by foshizl:
[ June 03, 2003: Message edited by: foshizl ]<hr></blockquote>
What is that supposed to mean????
Well, I clicked your profile and that is what YOU put in there, is that correct?
You MIGHT be able to get away with a 100 shot..... MIGHT, but for advice I ALWAYS suggest staying with the kits intended nitrous jettingRace car - gone but not forgotten - 1997 firebird V6
