ok guys i really wanna go up to a 100 shot, i just wanna get a inline pump first, take a peek at my mods, is there anything else that i NEED to get??
fuel pump then 100-shot?
Free ram air mod?
Got pic's of those headers installed?
Go with an in tank pump instead of a piggy back style
I run granatelli 255 lph with my 100 shotRace car - gone but not forgotten - 1997 firebird V6
What kind of plugs are you running??Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
im running the ngk tr-6 plugs, and taylor pro wires.
and 12sec.. i dont have pics, but take a peek at my post in exhaust(its guardianknights thread, ordered cia headers or something?)
oh and i was thinkin about the walbro pump, but dont you have to drop the tank to install the in-tank pump? im really not about payin $200 in labor, plus i hear from a few people that the intank isnt really necessary, and the inline will be fine, as well as easier and cheaper.
and what about retarding timing? its somethink i know nothing about really? so i need to look into it??later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
walbro or granatelli 255 lph in tank pump only.
If you get the inline piggy back style the fuel still has to go through your stock fuel pump.
I really think that an in tank should be done over a piggy back style
I run a 100 shot and stock timing.
I do run NGKTR6's which are 2 ranges colder
I try and run a minimum of 93, if it is slightly warm then I'll have 94
If it is REALLY hot then I'll head off to get 100 octane just to be safe
aalugo2000, I'll checkRace car - gone but not forgotten - 1997 firebird V6
hey 12sec...
on that intank pump, do you have to drop the tank to install it? or can you get it through the back seat? how many hours u think it would take?
and also, you say your running stock timing? i heard you should retard like 2degrees or whatever for every 100hp of spray, obviously you've been spraying for awhile now, so why didnt you do this?later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
The fuel pump can be changed without dropping the tank...a friend of mine did it to his SS and we will be doing it to mine shortly. I will try to find a website that shows each step, and has good pictures. That's where he learned how to do it.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
<blockquote>quote:</font><hr>Originally posted by 12secdream:
i used a dremel and cut a small square out on my back hatch, then i pull the pump from there.
all in all it took about 1-2 hours.. not bad at all.<hr></blockquote>
Yep, that's basically it.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
You can cut the metal above the tank.... but not reccomended.
You can partially lower the tank and switch pumps
As for timing..... I run 2 ranges colder plugs and high octane gas.
If it is really hot out 100 octane.
I like to have 94, 93 will do.
I haven't experienced any issue's yet.
Higher levels like a 125+ shot will require 100 octane, plugs that are 2+ ranges colder and 1-2 degree's of timing yankedRace car - gone but not forgotten - 1997 firebird V6
