so i was doing phase III of my nitrous install today (that being hooking up the fuel lines) and i was having a hard time hookin up the fuel pressure regulator ish and the t and all. so i thought, there has to b a better way, and lo and behold, if u follow the line w/ the rubber elbow that taps into the fpr (the one that gets t'd) around the back of the manifold and to the other side, the other end comes off just as easy as the first. so u just take this little 6 inch line out, hook up ur t and lines to the solenoid, then just plug the stuff back in. done w/ that in under 5 minutes.
now... if this isn't the right line to tap into, somebody tell me fast! if it is the right line, then i'll take some pats on the back right about now :D
