Why cant we spray more then a 100 dry shot - FirebirdV6.com/CamaroV6.com Message Board
  • Why cant we spray more then a 100 dry shot
    What is the reason that keeps us form spraying a higher dry shot.
    Fuel? what about with a walbro intank, that would solve any fuel problems from the tank. Injectors? whats the real size of them? 12sec if im not wrong said he heard 19lbs while the tech base says 22lbs. What would it take to run more injector with out computer tuning. What is the biggest injector someone is running with stock programing.
    Just bring some stuff up to talk about, its too quiet in here
    My understanding is that the MAF sensor can't sense that much more oxygen in the intake.
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      then how do them dam ls1's run a 200+ dry shot there is still a point where they max our their maf too
        Seppo is running stock LT-1 injectors which I believe are 24lbs. James(12sec) is running bigger injectors as well.
          LT1 injectors are 22#
          96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
            the ls1's maf will register between 450 and 550 hp, depending on year, and dispersion of nitrous.
            98's have the least, with 99-02 the same.
            With that large of a dry shot ls1, you need to upgrade injectors, but that is easy, because you can tune the ls1 computer. something not easily done with your computers :(
            for instance, i have some 42# injectors in my closet now, that will go on with the blower, and i can tune those to drive perfect on, no problem.
            But without proper tuning, trying to use a maft, and AFPR, your never going to get it to run right.
            Ryan
            [ January 20, 2004: Message edited by: slow ]</p>
            1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
              i think JohnD. ran a 150 dry on his car, James used to run 120 dry, Min ran 150 dry a while ago too i believe...its just risky and most people dont wanna mess anything up...
              [ January 20, 2004: Message edited by: WickEdSix9838 ]</p>
                <blockquote>quote:</font><hr>Originally posted by Timbo1969:
                Seppo is running stock LT-1 injectors which I believe are 24lbs. James(12sec) is running bigger injectors as well.<hr></blockquote>
                Um, no sir.
                19 lb STOCK injectors with 90,000+ miles on them
                I sprayed a 120 dry shot.
                Fuel upgrades:
                kenne bell boost a pump
                AFPR
                Superchips custom programmed computer
                I tried bigger injectors and blew ther engine in under 30 days.
                &lt;--- still runs stock 19 lb injectors.
                  Lt1 injectors are 24Lb and I think people don't run more because they are scared.
                    Yep I ran a 150 dry shot with 24 lb Accel's and a boost-a-pump and a maft. I had to change the maft setting when planning to spray, and change it back when not spraying.
                    It's difficult to tune a big dry shot for correct ratio that will hold for both spray and na operation on the same set of injectors.
                    With a wet kit you can tune the na operation with a maft or pcm tuning, and then tune the spray simply by changing the fuel jet if necessary.
                    Also I was some some kr on the 150 shot...
                    \'98 A4 Camaro v6-&gt;v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
                      <blockquote>quote:</font><hr>Originally posted by slow:
                      Ryan
                      <hr></blockquote>
                      were you get your 42# injectors and how much you pay???????????????????
                      www.turbov6camaro.com
                      1997 3800 Series II Camaro
                        <blockquote>quote:</font><hr>Originally posted by viper04af:
                        <hr></blockquote>
                        I traded a new NX 15# bottle for them, so they cost me around 130 after selling the rest of the NX kit for 320. Normally they cost around 299 for a set of 8.
                        edit. Since i posted this thread, the HPtuner program came out, so many of the newer n20 guys, can possibly run larger injectors, and if the maf will read the additional air, spray a larger dry shot.
                        Ryan.
                        Ryan.
                        [ February 05, 2004: Message edited by: slow ]</p>
                        • Manimal
                          Coil springs
                          by Manimal
                          6 days ago
                        • Manimal
                          Newby here
                          by Manimal
