Got a question - FirebirdV6.com/CamaroV6.com Message Board
Got a question
  • Got a question
    Was wondering how much does the bottle pressure go down by the end of a run starting at 1000psi what is the psi at the end of a run
    Thanks
    Depends on many factor's:
    How much you are spraying
    How much is in the bottle
    How warm/ cold it is outside
    How warm the bottle is
    How many bottles you run in a tandem set up
      100 shot
      full bottle
      medium not really cold not really hot
      with a bottle warmer warming it up to 1000psi
      1 bottle
        also on a typical dyno run too would be great
          dont need an exact answere just something close.
          is it 700, 800, 900?
          and typicly how long does it take to get the bottle back up to 1000psi
            100 shot is about 4 lbs per minute, so you could do a lot of math to figure out what the pressure would be...
            Or you could say ok, I have 10lbs to start, I run a XX.XX, so 4(XX.XX)/60 = how many lbs you use on a run. That doesn't help with bottle pressure but it helps you know how much juice is in the bottle.
            1997 Dodge Viper GTS
              no one knows?
              how much does your pressure go down 12sec with 2 bottles on a regular pass
                there is no way of positively knowing just like in thing with nitrous there never is a for sure answer sometimes your lucky and get alot sometimes your not
                94 Pontiac Firebird-V6<br />-NxWetKit,RamAir,MSD Dis4, Coils,&Wires,DynomaxExhuast w/testpipe,NittoDR\'s&DunlopSPort5000s,17\"CrEagleAl loys,TransgoShifKit/VetteServo<br />91 Jeep Wrangler-5.7 Chevy350<br />-6\"ProComp SuspensionLift,M/T BajaClaws35x12.5,& more goodies
                  I can't speculate on this.
                  With the dual set up I don't notice a psi drop.
                  2 bottles will typically last me a decent day at the track
