ok heres the first question: how much will this hurt my motor if at all? next will this add a high intercooling effect if i put it in before the turbo, i want to use it to cool down the turbo a little and the air a lot. now would this really add much hp from the nitrous or would a lot of it be lost by going throught the turbo, the piping and the intercooler. i know very little about nitrous but it doesnt scare me as much as it use to so i think i might want to look into it now.
25-30 dry shot with turbo
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
get the n20 intercooler cooler thing, nitrous express makes one. it sprays the juice on the intercooler thus cooling it of.2002 NBM Pontiac Firebird Formula<br />Mods: stock...<br />1997 Chevy Camaro *Gone*<br />Mods:Borla,headers,Magnaflow cat, SLP intake, NOS 5175
You could do that. You would just need enough fuel injector to do it.
I see some people doing the jet before the compressor inlet thing, If you have an inter cooler I wouldn't do it there.
For the best cooling effect just put it in frount the MAF close to the TB.
I wouldn't do the inter cooler gas sparyer thing, I think it is to little for to much money and wouldn't last long engough me.
I want to equip my car with a 16-20quart camping cooler in the trunk and just fill it most way with ice and water and run a line from the drain to pump water and squrt it on the Intercooler.
You could service it at any gas staton with water and ice Unlike haveing to get a canester filled by a gas bottler.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
not a good idea because you'll be dripping water all over the ground, that would probably get you kicked off a drag strip for repeated "drippings" on the line and down the track...plus you have a chance of spinning in the water too...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
yep it will work and work very well but with anythign make sure you are getting enough fuel and it will be a tid bit more strain on the internals.
im going water cooled with the intercooler and i dont thing spraying the radiator for it will help as much as an air to air system. i'm probably going to start there but if it doesnt help much i would like to have a use for the nitrous equipment and i think this would help. thanks for the info so far, keep it comin if you can add anything now that i have made my post a little more specific.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
