Nitrous gurus. got $1200......what to buy - FirebirdV6.com/CamaroV6.com Message Board
  • Nitrous gurus. got $1200......what to buy
    k guys, since i cant have a turbo or SC (thx california) im gonna go the nitrous route. help me out by tellin me what i should get.
    im only gonna actually have 1000, cause 200 is going towards a new video card.
    im about to buy a set of heads soon, so think of that while contemplating
    I guess I\'d have answer your question with another question.<br /><br />How many Abidiginals do you see in modeling??????<br /><br />headers, 3inch magnaflow cat, Loudmouth<br />99 Midnight Blue Firebird<br />3.8L A4
    Invest it and buy a LS1 in a couple years.
      would, but i cant..........california again. im pretty sure ill get nabbed on it on the visual inspection.
        you shouldnt get in truoble, even for the visual. If you pass emissions for a 99 V6, and you actually have a V8, you should get a pat on the back I should think. ;)
        Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
          Ask Kristen.
          She just bought a complete setup with a window switch. I'm sure she can guide you as far as part numbers and best purchase price....
          1995 3.8L Mustang<br /><a href=\"http://www.bmnracetech.com\" target=\"_blank\">http://www.bmnracetech.com<br /></a>
            NOS KIT 5175
            FPSS
            Bottle blanket
            bottle warmer
            blow down tube
            Viola, I bought ALL of those things at once from www.summitracing.com Great deal!
              P&P heads for around 500 dollars,
              P&P intake's for around 200
              cam for around 200
              Jeff ..
              1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
              2002 WS6 T/A.. Bolt ins..448rwhp
              2009 G8 GT.. Vararam intake, GXP axleback
              1998 Corvette.. Vararam intake, Ti axleback
              http://www.fquick.com/slow-v6
                NX GM FI Kit (wet)
                GenX-2 upgrade
                thatll put you at about 950 or so. save the extra money to fill the bottle.
                  Originally posted by 12secondv6:
                  NOS KIT 5175
                  FPSS
                  Bottle blanket
                  bottle warmer
                  blow down tube
                  my NOS kit 5175 came with the FPSS(flue pressure safty switch) and blow down tube.
                  2002 NBM Pontiac Firebird Formula<br />Mods: stock...<br />1997 Chevy Camaro *Gone*<br />Mods:Borla,headers,Magnaflow cat, SLP intake, NOS 5175
                    NOS-ZLE direct port universal V6 kit
                      Originally posted by Silv6:
                      QUOTE]my NOS kit 5175 came with the FPSS(flue pressure safty switch) and blow down tube.
                      Mine didn't have the FPSS
                        I'm still learning about the 3.8 F-bodies....
                        The NOS-ZLE setup have been proven to be sketchy on some returnless systems.
                        Did these cars (V-6 F-bodies) ever have a returnless fuel system?
                        If so, what year did GM migrate to that setup?
                        Any info appreciated.
                          I would get a NX kit, Gen X-2 upgrade, and Nx style switch panel and custom wiring harness for your $1000
                          Ryan
                          1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
                            My 97 is a return system, all of the 3.8 v6 f bodies are return fuel systems.
                            I'm not a fan of the NIOSzle systems due to yielding lower RWTQ numbers
                              Ahh, I see. Thanks for the info!
                              Yea, there was a bid discussion about the Noszle setup on one of the mustang forums awhile back.
                              Here is what was relayed to us in the conversation:
                              Here's what the tunner told me the problem is:
                              "it's really the way the system is designed to intergrate with the returnless fuel system - it's a bad design. It must have been rushed to market by someone who didn't really understand how a returnless fuel system works. In an electric returnless fuel system vehicle, the returnless system actually controls the pressure drop across the fuel injectors. It does NOT control fuel rail pressure. The sensor on the fuel rail has a manifold vacuum/boost line hooked to it that feeds it the pressure/vacuum in the manifold. The sensor is mounted to rail so the output of the sensor is actually the pressure drop across the injector. The flow of a fuel injector is dependent on the pressure drop across the fuel injector.
                              So, the PCM is getting pressure drop feedback from the sensor and controlling the fuel pressure drop across the fuel injector. If the pressure is too low, it increases the voltage to the fuel pump to get it back towhere it should be. If the pressure is too high, then it lowers the voltage.
                              When you are pulling fuel from the fuel rail where the N.O.S. system is hooked up, you are really messing up the pressure drop across the injectors, it's oscillating between under and over compensating"
