Rockers - FirebirdV6.com/CamaroV6.com Message Board
Rockers
  • #16
    Okay so it is roller just no roller tip? I guess that settles my new rockers or not question...roller without roller tip to roller with roller tip at the same ratio (1.6 is what they come with stock right? that's all I would do cause of cam anyway) wouldn't give me any real gains.
    Sweet.
    2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
    • #17
      Sweet.
      Yep, 1.6 is stock. I was looking at the roller rockers at intense, and they say if you're going to 1.9, to also upgrade the springs to medium duty. Would this be totally neccessary? Or do you think we could sqeak by with the stockers?
      2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
      • #18
        i would get the springs, the last thing you want is valve float.
        • #19
          When dealing with your internals or valvetrain, if you have to use the phrase "squeak by" it means it's probably not a good idea.
          AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
          • #20
            yeah, you're right. I guess my problem was that I've never done valve springs before. It doesn't look hard at all, it's just I've never done them before. What about the pushrods though. Do you think it would be a good idea to upgrade them when you get heavier springs (intense say you don't need to, but I don't mind upgrading, if beneficial)?
            [ November 17, 2004, 11:04 PM: Message edited by: majeskyb ]
            • #21
              Everything is fairly easy to replace except the springs (also locks and retainers) and the lifters.
              The lifters are bad because you have to pull the intakes.
              The springs aren't as bad, as long as you have a small spring compressor, and an air fitting to put air in the cylinders.
              1997 Dodge Viper GTS
              • #22
                Holy crap... post brought back from the dead?!?!?!?!
                With my SLP 1.8's I added titanium retainers and 105 springs
