Whats the most u can use on the 3.4l?
How much on a 3.4l
i wouldnt push over a 55 shot, but make sure you have all the supporting mods!!94 firebird, flowmaster 80, no cats, ZEX dry kit-SOLD!!!<br />1997 camaro SS- lots of mods, thrown rod at the moment,awaiting 383<br />1990 plymouth laser RS turbo-14.5@94<br /><br /><a href=\"http://www.baycityrides.com\" target=\"_blank\">www.baycityrides.com</a>
I got a 1995 camaro with a 3.4l, fully rebuilt from bottom up with all new bearings + 25 over, comp cam cam,rockers,springs,pushrods,accel injectors, slight p/p heads, slp cold air intake,pace setter headers rebuilt tranny tci 3000 stall. alum drive shaft, and a posi with a 410 gear. I have a zex dry kit and sprayed a 75 shot it took my time down from a 16.3 to a 14.9. i was wanting to know if i should move up to a 100 shot or even a 125 if i get some tuning done from fast chip.Come Check out my car and sign my guest book <a href=\"http://www.cardomain.com/id/chevyfreak_boy\" target=\"_blank\">http://www.cardomain.com/id/chevyfreak_boy</a>
Dunno, asking what is the most you can spray depends on sooo many things
Temp, fuel you use, engine set up etc.
Sorry, I'm not making guesses on this oneRace car - gone but not forgotten - 1997 firebird V6
I have a 94 with a 3.4L i run an nx wet kit with a 75 shot and its fine.
just dont run platinum plugs. they recommend a step colder but i didnt do that.Check out my car @ <a href=\"http://www.grodzmotorsports.com:8080/camaro2.html\" target=\"_blank\">www.grodzmotorsports.com:8080/camaro2.html</a> <br /><br />It\'s not what you make, it\'s what you spend! <br /><br />1994 Chevy Camaro 3.4, m5, t-tops, silver exterior, gray interior.<br /><br />Many modz! check out the site for details!
I run a 100 shot on mine without any problems. I am running one step colder plug and retarded the timing by 4*. I tried a 150 shot once and it made 3 passes without any noticeable problems until it started overheating. I didn't have studs on it and it stretched the new stock head bolts and baked the gaskets. I have the studs on it now and I don't have any problems.
Originally posted by nosinjected956:
I got a 1995 camaro with a 3.4l, fully rebuilt from bottom up with all new bearings + 25 over, comp cam cam,rockers,springs,pushrods,accel injectors, slight p/p heads, slp cold air intake,pace setter headers rebuilt tranny tci 3000 stall. alum drive shaft, and a posi with a 410 gear. I have a zex dry kit and sprayed a 75 shot it took my time down from a 16.3 to a 14.9. i was wanting to know if i should move up to a 100 shot or even a 125 if i get some tuning done from fast chip.:eek:
Originally posted by 12secondv6:
I'd be going 2 ranges colder w/ the plugs
And, for fuel, 150 shot... 100 octane
