thanks a lot for all the info man..thats a BIG help..im supposed to get my nitrous on saturday before i go run on sunday..so i'll post a log file here this weekend [img]smile.gif[/img]
Injector question for juice
Originally posted by 1DangerousV6:
cuz one of your 19s went bad on a 120 dry shot..which is my current setup ;)
Not 19.
I don't remember.... been ages....Race car - gone but not forgotten - 1997 firebird V6
it says that when you first started running a 120 shot (this is what..like..4 years ago?)..that you hit a 12.8 ..and then one of the stock 19lb injectors went bad on you..so you dropped in 24lbers..thats when..since your car wasnt tuned for them..you dropped a rod..but oh well..i'll just watch it..and if i need bigger ones then i need bigger ones..HP Tuners wrote back to me and said ..
"I'm not sure what the factory injectors are but the PCM is setup for 22#.
Chris..."
so now i dont know whats going on..i know it tells the PCM to make adjustments based on vacuum pressure..but it also says that THATS the table that tells it what size injects are there..and the value there stock is 22.18
They probably are 22#. But again, don't worry about it. The scanner will tell you all you need to know. If you need new injectors, you will be changing the value anyway.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
yeah thats what i figure..oh well! [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
i just talked to summit racing..they said that 19# are stock..and that the accell injectors..as far as dimensions and plug style and everything..are a direct replacement/upgrade..so if it turns out i need bigger ones i'll just get a set of accells [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
You can get a set of GTP injectors off ClubGP.com for about $50-$75. They are a direct replacment for your injectors and at 36#, they would be perfect. It would take about 30 minutes to change them.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
i thought you had a crap load of trouble with these and so did AllTheGoodNamesAreGone..the plugs to the harness or where they connect to the rail didnt match up or something?<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
2000+ has different injectors. The 1998 it is plug and play! All you have to do is copy the injector table from a GTP bin on the bid depository or I can post it up here.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
sweet!..what year (or range of years) GTPs am i looking for?..any?
[ March 30, 2005, 04:28 PM: Message edited by: 1DangerousV6 ]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I know 2003 and earlier will work. I am not sure about 2004+.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
Maybe I did have 24's [img]tongue.gif[/img] Been ages.
The accel's were a direct replacement... I have the accel 19's nowRace car - gone but not forgotten - 1997 firebird V6
i was looking at the accels if im gonna need new ones..but now i just got a deal on a set of 99 GTP 36# injectors for $35 shipped! ..whether i need them now or not..cant turn down that price [img]smile.gif[/img]
[ March 31, 2005, 09:42 AM: Message edited by: 1DangerousV6 ]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
also..i remember you having to adjust the height of the fuel rail for these..am i going to have to do that on my 98??
[ March 31, 2005, 03:09 PM: Message edited by: 1DangerousV6 ]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
GTP
injectors require modifications..... accel's are drop in.... for a little bit more money I'd prefer to go with what works right away.
A fuel system is THE MOST IMPORTANT part of a nitroused carRace car - gone but not forgotten - 1997 firebird V6
