HI, I'm an idiot. I thought I could put in a zex kit without having much trouble but it is a pain in the ***!!! If any of you could spare some time for a fellow fbody lover it would make and save my day.
spects: 1994 3.4L
questions:
1. The wire that some how suppose to attach to the throttle sensor wire...I have no clue how to connect it or which one of them to connect it to..provided I'm even looking at the right unit on the passanger side of the veh, I think it is the one with the four wires on it at the very top across from the throttle wires.
2. How and where do I hook up the fuel pressure regulator tubes? Both the intake and the one that is hooked to the fuel pressure regulator...I have no clue where the stuff is on the car to hook up to...haaaaaaaaaaaaaaaaaaaaaa!, I "think" the fuel pressure regulator is on the top of the engine and the intake tube is suppose to attach to that mettle tub on the ruber air induction tube after the air filter...again I have to clue...please help, I'm trying to learn this but its a pain....and people always said how easy it was..sure if you know where to put the ****.
spects: 1994 3.4L
questions:
