I'm gonna buy that NOS 5175 kit... what all can I buy that's not included in the kit 2 make it as safe as possible? I made a little list but I don't wanna over-look anything in case their's just someth'n I don't know about.
Nitrous safety extra's...?
rpm window switch, and a fuel pressure safety switch probably comes with it, correct?
the fuel pressure safety switch will come with the kit..as well as a wide open throttle switch..although a window switch is primarily used to control backfires and is therefor more useful on a wet kit..its never a bad idea..i find a dry kit (what 5175 is) will work best with the bottle pressure between 1000 and 1100 psi..so you'll want a bottle heater..i suggest one that is pressure controlled (by a pressure transducer) and not temperature controlled..also..if you try to inject not knowing you are out of nitrous..you can run very rich and foul your plugs..so you'll want a pressure gauge..i would also recommend NGK TR6 plugs gapped a .035..so..the list..
1: window switch
2: pressure gauge
3: bottle heater
4: NGK TR6 plugs gapped at .035
..use as instructed and have fun [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
A few idea might beRPM shut off (windo sw.) WOT switch, fuel pressure sw and stuff along with my exhaust O2 safty swithch when I build it.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
