What all upgrades are good for nitrous? What fuel pressures are safe? So far I have fuel pump... and I'm not quite sure what fuel pressure regulator does as far as like... translated into non~engine tech language as in like... adjustability... how should it be set? Also has anyone upgraded their injectors?
Fuel Delivery
try reading the stickies marked with "!" ..you'll find a lot of your answers there..as far as injectors..you would only need to upgrade injectors if you are running a dry kit..but id say the stock injectors can handle a 120 dry shot..and ONLY do this if you can tune the PCM for the flow rate change..many members here have done it..but it sounds like you may need to do a bit more research on nitrous first<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
