Im going to get an oil change here soon, Is there any type of oil I should be using while using nitrous or is the usuall just fine as long as I dont let it get to old or go through too many miles??
Type of oil while using nitrous??
the usual is fine..but if using nitrous you may want to change it every 2000 or so instead of every 3000<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
this is the oil i use. i change my own oil.
http://www.quakerstate.com/pages/pro...chighhorse.asp
if you go from normal oil to Synthetic oil, your might find leaks. since Synthetic oil is thiner, it will clean out everything in there and then the oil will just leak, my rear main seal when :rolleyes:
^yup..the pinion seal..happens to a lot of us<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Originally posted by 1DangerousV6:
^yup..the pinion seal..happens to a lot of us<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
I use Mobil 1 10W30 Synthetic since about 10k miles and have never had any issues. The oil doesn't come out all black like standard either, it's more like syrup and comes out thin not all sludgy. I change mine every 3k miles religiously, but once I start spraying I'll change it more often, probably every 2k miles like someone else suggested. Oh, and I use K&N oil filter's too! From all outward appearances it seems far superior to any other, plus it's longer than the stock one.2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
Here's a secret...
You can get a Mobil 1 oil change at Walmart for just about $30. That's cheaper than most of us can buy the oil and filter for!
...and the Mobile 1 extended life oil change is just ~$35.
I've never put anything but Mobil 1 in my engine. Think of it as cheap insurance.1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
Originally posted by Bird_Of_Prey:
</font><blockquote>quote:</font><hr />Originally posted by 1DangerousV6:
</font><blockquote>quote:</font><hr />Originally posted by Bird_Of_Prey:
Originally posted by 12secondv6:
I went through 3-4 LSD units?
Locker OWNZ!!!!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Yup, 3 LSD units.... then I finally got a locker [img]smile.gif[/img]www.turbov6camaro.com
1997 3800 Series II Camaro
