i just got the kit and theres a couple qestions i have, what is the tubing that has a 90 degree bend in it that has the red nut at the end of it used for? also how is the fuel pressure safty switch hooked up? do i use braided line from the pressure relief on the fuel rail to the bottem of that? i looked in the manuel but didnt see anything. thanks alot
question bout the 5175 kit
-K&N FIPK Air Intake<br />-TB Bypass<br />-Manuel Fan Switch<br />-Stage 2 Jet Chip<br />-Hypertech Powerstat 160<br /><a href=\"http://www.cardomain.com/ride/2023393\" target=\"_blank\">http://www.cardomain.com/ride/2023393</a><br />-UD Pulleys<br />-Adjustable Panhard Bar,STB<br />-BBK Fuel RegTags: None
there should be a 90* swivel fitting..that hooks up to the fuel pressure safety switch..im not exactly sure which tubing you're talking about..if you check out the install instructions and give the part number i could tell you exactly what its for [img]smile.gif[/img]
..by the way..do not use the jet chip with nitrous<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Stage 2 Jet Chip is in your sig.... you have removed this yes?
tubing that has a 90 degree bend in it that has the red nut at the end of it used for: are you talking about the blow down tube? Dunno.... get a pic
also how is the fuel pressure safty switch hooked up: there is a threaded portion on it... while a friend is in the car quickly turning the ignition on (to pressurise the fuel lines) and pressing your nitrous buton listen for the soleniod opening.... adjust the screw until you stop hereing it open
do i use braided line from the pressure relief on the fuel rail to the bottem of that?:I had a 90 degree hard metal line and had a t fitting to the wet kit solenoid and FPSSRace car - gone but not forgotten - 1997 firebird V6
ya the jet chip is on its way out, the part looks like a blow down tube but is like 3 inchs long and i cant find a part number in the instuctions-K&N FIPK Air Intake<br />-TB Bypass<br />-Manuel Fan Switch<br />-Stage 2 Jet Chip<br />-Hypertech Powerstat 160<br /><a href=\"http://www.cardomain.com/ride/2023393\" target=\"_blank\">http://www.cardomain.com/ride/2023393</a><br />-UD Pulleys<br />-Adjustable Panhard Bar,STB<br />-BBK Fuel Reg
I am in the process of installing my 05175 kit tonight too, i think that part goes off the schrader valve and into the fpss (if you read the bottom of pg14 in the instructions it says "Note: ...05175 includes an extenstion tube for the fuel rail test port.")
You also need to take out the fitting inside the schrader valve before doing this.
Someone please correct me if I'm way off...Old Car = 12.679 @ 106.5 on 150 dry shot.
New Car = 2010 3.6l 304hp Camaro
Someone please correct me if I'm way off...1997 Firebird, A4,WS6 Ram air hood, edelbrock catback, SLP CAI, 85 dry shot<br />1981 Firebird Trans Am<br /><br /> <a href=\"http://members.cardomain.com/dreaded_hope\" target=\"_blank\">http://members.cardomain.com/dreaded_hope</a>
I am in the process of installing my 05175 kit tonight too, i think that part goes off the schrader valve and into the fpss (if you read the bottom of pg14 in the instructions it says "Note: ...05175 includes an extenstion tube for the fuel rail test port.")Old Car = 12.679 @ 106.5 on 150 dry shot.
i think you have to take the whole valve out of the fuel rail.is that right? thats what had me all messed up-K&N FIPK Air Intake<br />-TB Bypass<br />-Manuel Fan Switch<br />-Stage 2 Jet Chip<br />-Hypertech Powerstat 160<br /><a href=\"http://www.cardomain.com/ride/2023393\" target=\"_blank\">http://www.cardomain.com/ride/2023393</a><br />-UD Pulleys<br />-Adjustable Panhard Bar,STB<br />-BBK Fuel Reg
You must remove the shrader valve from the fuel rail.
Bird is outside.... I don't remember having difficulty hooking up the FPSS line to the fuel rail.... I gotta look at my bird and see if I did anything different thoughRace car - gone but not forgotten - 1997 firebird V6
correct..you do not want to advance timing with nitrous..a rule of thumb is that you actually retard the timing 1* for every 50 addition horses of nitrous for the street..for the track..it would be 1* for every 50 addition horses -1*..but for an 85 - 100 shot i would say it is ok to run stock timing as long as high octane fuel (92+) is used<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
