Ok, my nitrous kit will be installed soon. I have the FPSS, WOT switch and the digital window switch. I'm guessing the window switch will be set between 4000-6000 rpm. Is this good? I've heard people say you should spray at the top of second gear or anywhere for that matter but I don't what to spray off the line YET! I have an automatic and I'm at the tree, nitrous is armed. I floor it. I will be spaying off the line because I'm above 4000 rpm and I'm at WOT right? Hoe do I not spray off the line? Thanks
Stupid Question
you have an auto, so you won't be stalling up to 4k at the line, I see you have a 3200 stall. So you won't exactly be spraying right off the line, but real soon after.
But I don't want to spray off the line! What do I do? Not arm it till second gear?2001 FirebirdW68<br /><br />Whisper Lid; SLP CAI w/K & N, Flowmaster Am. Thunder, B & M Shift kit w/ Servo, 3200 stall Edge Racing Converter, Tranny Cooler, Nittos, 180* stat, Taylor Spiro Pros w/ NGK\'s, MAFT, Royal Purple.
Like 97rs4life said, you won't be spraying off of the line.. Spraying off of the line means spraying from a stand-still, a dead stop, i.e. your launch. You'll be spraying after you start moving and your rpms climb up to 4k.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
