wiring purge kit and mounting bottle - FirebirdV6.com/CamaroV6.com Message Board
  • wiring purge kit and mounting bottle
    ok i got my nitrous kit and its the Dry zex smart kit. The guy sent me the kit with the purge still hooked up to the smart box. The only problem is how do i hook up the switch and where should i put it in my interior?? Also i want to mount my bottle in the back seats right on the tranny hump. Im gonan completly remove my back seats and fabricate with wood all evenly with the hump so technically that tranny hump will be parralel with the wood them im gonna carpet it so you cant even tell. If i mount my bottle there in the back seat where can i run the nitrous line to under my car to the front?? and should i go through the firewall or under it? any info will help..thanks
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    I mounted my bottle in between the back seats on a wood box as well. I then secured the box by running brackets to the seat belt bolts. My nitrous line goes through the grommet at the bottom of the rear seat and under my car. I just cut a slit in the rubber grommet and pushed the line through it.
    http://memimage.cardomain.net/member.../278896_12.jpg
    I have all my switches in a switch panel I made that goes into the hole next to the cig lighter. I got a convertable switch plate and drilled holes for my switches in it. I have activation, purge, and bottle heater on the switch panel.
    http://www.bowtiev6.com/
      i have the switches placed right under the gauge cluster..kind of near the ignition..its a good spot because it is not far from the stearing wheel so its quick easy access and you dont have to let go of the wheel for long..as far as the bottle placement..thats exactly where i have mine..my main feed line comes out of the bottle and then down under the center console..from there it goes down through the car floor and all along under the car up to the engine bay..you kind of want as little nitrous lines inside the car as possible
        ok i took out my driver side passanger seat and made a wooden board and bolted it down to the seat bracets. Im gonna carpet it too but thats when im totally done with everything. As for the rubber goramet under the rear passanger seat...where exactly? i have never seen one there but then again i havent really looked...i take it i hafto peel back all the carpeting and then i will find it?...also when i get into mounting my smart box under the hood where is prolly the best place to mount it that i can reatch everythin to hook it up?? and where can i run the wires through my firewall for all the switches and purge kit...i have a system and my wire is ran through on the passanger sie through a garamet but thats too far away from the middle consol for the wiring...
          alright i just looked at the link u sent me and those 2 holes is where i mounted the wood ontop of...so tomarrow i will pull that off and run it through there...thanks for the help everyone
            There is a slit in the carpet under the back seat that I looked through and grabbed the grommet. Just look under the carpet in the hole where the seat was and you will see it. Look at the picture link I posted above, that is what you will see.
            My wires go through a hole I made on the driver's side firewall.
              ok i need some help on the wiring with the switches. From the zex smart box theres A red wire (power), a Black wire (ground) and the white wire (TPS wire)...now i also have the purge kit which has a Red wire (power) and the black for the ground. How can i wire these up. I have 4 different switches that came with my kit. One push button one, The flip activation switch that comes with the kit, A small On/off flip switch and then theres a black round one that you switch and when its on a little red dot lights up red. This one has 3 Metal prongs on it. I take it 2 are power and ones negative? anyways im just confused on how to wire up the nitrous activation switch along with the purge switch..
