Adjustable Nox kits - FirebirdV6.com/CamaroV6.com Message Board
Adjustable Nox kits
  • Adjustable Nox kits
    Alright for those of you with adjustable kits. witch kit do you have and how do you adjust it? is thier suck a think as a remote adjustable kit i can adjust from my drivers seat or would that just be like a 2 stage. i want to run a mild amount regulary but wanna kickit up when i c a corba or modded GT or reg Z-28. i am not even sure if i have room in my trunk for a bottle of nas how big is a 10 lb bottle? thanks for any responces
    If you want an adjustable system from the driver's seat it will probably cost you way more than you want to pay for a v6. It is possible but you need a nitrous control module (i think thats what it is called) and they cost anywhere between $200-$350. Plus I dont think you can hook those up to just any nitrous system. The horsepower gain for most kits are only regulated to how big the jet is into the motor. Big jet=more horsepower.
    The easiest way to adjust your system is to simply buy more nitrous jets and just install them whenever you want to use them. Its easy: pull out the jet, unscrew it, put in a new one. Done. New jets are $7.95 a piece from Summit.
    [ March 10, 2006, 01:26 PM: Message edited by: Shodown ]
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      you could setup two nozzles and have activation switches for both of them. Like a manual two stage system. You would still need the extra solenoids for the second nozzle and then a y connector by the bottle to split the nitrous to the two lines unless you ran two bottles as well.
      http://www.bowtiev6.com/
        And abut the bottle I don’t think you can fit it in the trunk because you need to aim the bottle in the direction of trawled and because you have a convertible it will not fit, its only possible if you take out your spare tire but I will not recommend putting it there because it is to close to the body if you get hit BOOOOOOOOOM
