i got the 5175 kit and was wondering which size purge line to get for it 4AN OR 6AN? THANKS
purge nos help
purge nos help
-K&N FIPK Air Intake<br />-TB Bypass<br />-Manuel Fan Switch<br />-Stage 2 Jet Chip<br />-Hypertech Powerstat 160<br /><a href=\"http://www.cardomain.com/ride/2023393\" target=\"_blank\">http://www.cardomain.com/ride/2023393</a><br />-UD Pulleys<br />-Adjustable Panhard Bar,STB<br />-BBK Fuel RegTags: None
there is no line that goes directly to the purge solenoid on that kit if it is set up correctly..the 4AN main feed line goes to a nut fitting..the purge solenoid then connects to that fitting via a stright male/male fitting
go here for instructions and diagram..
http://www.holley.com/data/Products/...A5155-SNOS.pdf
[ March 18, 2006, 07:47 PM: Message edited by: 1DangerousV6 ]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
