I have a buddy who recently installed a NOS 5175 kit on his camaro. Today he got his bottle filled and when we filled the line, his pressure gauge doesn't move (it is mounted on the bottle with the line). It reads 0 PSI yet. Everything looks right so it is a little confusing. Any ideas why it isn't reading the pressure? When we compared it to my setup it was pretty similar and it should be reading pressure.
Nitrous Pressure Gauge
Tags: None
Re: Nitrous Pressure Gauge
Could be a bad gauge. Does he have a purge kit? If he does, try purging it first to see if anything happens. You should also be able to take out the nozzle from the intake and spray it manually into the air just to see if there is pressure.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
oh there is pressure, everything else works fine. the gauge just isn't reading pressure.
Im going to play with it a little this afternoon..take it apart and inspect it, but ill take any ideas....
Just a little confused because there is definetly pressure there!!
Ill keep you updated1997 Camaro RS- Y87<br /> -Headers-Exhaust-CAI-Ground FX, Blah Blah Blah...Nitrous???<br />Check it out:<br /> <a href=\"http://members.cardomain.com/silver6_maro\" target=\"_blank\">http://members.cardomain.com/silver6_maro</a>
Originally posted by 97rs4lifeoh there is pressure, everything else works fine. the gauge just isn't reading pressure.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Just got back in the house from playin with it...
NOW the dynotune heater wont work either...its the pressure regulated type, and i checked all the connections, power and grounds....clueless...the switch lights up, i dunno
Took the hose off the nozzle, started the car and just pushed the WOT switch and it worked great, and the purge too, so it works, just the pressure gauge and heater i guess??1997 Camaro RS- Y87<br /> -Headers-Exhaust-CAI-Ground FX, Blah Blah Blah...Nitrous???<br />Check it out:<br /> <a href=\"http://members.cardomain.com/silver6_maro\" target=\"_blank\">http://members.cardomain.com/silver6_maro</a>
hey wasn't there an inline fuse for that heater? Check and see if that isn't blown
checked it, and also checked the accessorie fuses for power, and all are good1997 Camaro RS- Y87<br /> -Headers-Exhaust-CAI-Ground FX, Blah Blah Blah...Nitrous???<br />Check it out:<br /> <a href=\"http://members.cardomain.com/silver6_maro\" target=\"_blank\">http://members.cardomain.com/silver6_maro</a>
did you adjust that screw at all on the heater? It said to turn it till it popped or something and then that would put it at 900psi. From there you would then have to adjust it more to wherever you want it at
Finally got around to checkin this thing out....
The in-line pressure gauge still isnt working (yes the bottle is open) and i did try everything....its gotta be broken, but i didnt know it was that easy to break??
As for the bottle heater...the switch lights up like its on, but nothin happens.
I double checked all the wireing, grounds, and power....its got it all, but it will not heat up..
The instructions say to turn the allen wrench screw on the regulator clockwise till it clicks, and i did like a whole turn, and got no click....do i go more??? Plus having the gauge not working makes it hard to determine what that thing is reading ya know...
This just doesnt make sense because it worked the first time i turned it on, and now i get nothin.....so can someone tell me what is broken??1997 Camaro RS- Y87<br /> -Headers-Exhaust-CAI-Ground FX, Blah Blah Blah...Nitrous???<br />Check it out:<br /> <a href=\"http://members.cardomain.com/silver6_maro\" target=\"_blank\">http://members.cardomain.com/silver6_maro</a>
about the heater..if the directions say turn it until it clicks..then do just that..dont stop at one turn..turn it until it clicks
as for the pressure gauge..it seems to me that there are only two possible scenarios..either nitrous pressure is making it to the gauge and the gauge is not registering it..or nitrous pressure is not making it to the guage
remove the gauge from the nut adapter coming off the bottle..then..carefully open the bottle very slightly..if nitrous is coming out of the hole where the guage should be..then the fitting is fine and there is no blockage there..next check the little pin hole where nitrous is supposed to enter the gauge..if all is clear..then i would assume you have a bad gauge
im assuming the transducer for the bottle heater comes off of the same nut adapter as the gauge?..maybe there is blockage in the nut adapter and the heater is not coming on because it does not sense any bottle pressure..so i would take those things off and check it out<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
def. a pluming blockage. Did he use teflon tape or the spread on teflon tape?Last edited by teal99camaro; 04-13-2006, 08:59 AM.Mystic Teal Metallic
Silly question, you weighed the bottle correct?
Ok.... bottle guage is a no go.... it is an electrical one right? If yes, I'm probably your last person you want to take electrical advice from.... all I can say is check all connections and procede from there.
As for bottle warmer..... to make sure the warmer itself is working ages ago I just lengthened the positive side and slapped it on the battery... this way I knew the warmer itself works... I do not suggest doing that to get the psi up... it is just to check the warmer itself.... then check all the wires, relays and fuses and go from thereRace car - gone but not forgotten - 1997 firebird V6
ok....got the pressure gauge to work, and its an in-line gauge.
I just took it apart and blew it out and cleaned it up....the guy before me used teflon paste, so i think a piece must have gotten into it. so it works great!!
As for the heater, ive been talking to a guy from dynotune and doing a few tests to make sure everything is working...so with his help, he said we will get this thing working great....ill let everyone know and thanks for the tips1997 Camaro RS- Y87<br /> -Headers-Exhaust-CAI-Ground FX, Blah Blah Blah...Nitrous???<br />Check it out:<br /> <a href=\"http://members.cardomain.com/silver6_maro\" target=\"_blank\">http://members.cardomain.com/silver6_maro</a>
Keep us updated!
Teflon paste is good.... tape is bad... just for nitrous kits though.Race car - gone but not forgotten - 1997 firebird V6
by PettrrHey all,
I know this is a Camaro forum first and foremost (mine's a ‘00 V6), but I figured I'd ask — does anyone here also mess around...13 hours ago -
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 week ago
