FPSS and Vacuum Line Question???? - FirebirdV6.com/CamaroV6.com Message Board
  • FPSS and Vacuum Line Question????
    I am in the middle of installing my NOS 5175 kit. Got the bottle mounted and hose run from the rear to the engine bay.
    What does the FPSS hook up to? Where does it go?
    I know the nitrous pressure pressure regular goes to a TEE fitting. One part of the tee goes to the fuel pressure regulator and the other says to "existing vacuum line" (instruction manual from Holley). Is that the vacuum line that was pulled off of the fuel pressure regulator?
    The instruction manual is extremely vague on this. It only shows pics of a 3.4, I have a 3.8.
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
    Re: FPSS and Vacuum Line Question????
    FPSS attaches to the schrader valve on the fuel rail (pass side). You need to relieve the pressure first in the system then take a tire valve stem tool and remove the little needle in the test port. Then the FPSS attaches to that. Do you have the correct 90* piece that screws onto this??
    The vacuum line is the one pulled off the regulator on the driver's side on the back of the intake manifold. You put the Tee inline with that and run it to the nitrous pressure regulator.
    http://www.bowtiev6.com/
      Yes, I have the 90* elbow for the FPSS.
      Okay, now I see whats going on with the vacuum line.
      Thanks for you help Travis! :rock:
      1997 Camaro RS A4
      2006 Chevy Colorado
        no problem, any more questions just ask.
          On the FPSS, which connection is the ground and which goes to the solenoids?
          1997 Camaro RS A4
          2006 Chevy Colorado
            either one works, no set side for each. It is just getting wired inline with the system so if there is a problem it breaks the circuit and you don't have your nitrous activating.
              Awesome. Thanks again. :)
              1997 Camaro RS A4
              2006 Chevy Colorado
                yup. :) Now get that thing hooked up and spraying already, lol, just messing
                  yeah its just an open or closed circuit..keep us updated :)
                  ____________________
                  12 SECOND NITROUS POWERED 98 A4 V6 CAMARO
                  www.MySickCamaro.50megs.com
                  SOON TO BE FEATURED IN CAMARO WORLD MAGAZINE!
                    Well, I'm came to a screatching hault...alternator quit so that takes priority for now. I should I have the alt by Saturday if all goes well. I bought one off of SexySixer. At least thats an easy fix, 1-2 hours tops and I will go right back into finishing up the nitrous.
                    While I am waiting for the alt to arrive I am going to finish the wiring, bottle opener and bottle heater though.
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                      You can still hook everything up and be ready to spray when the alt is on!
                        Yeah, thats the plan, but I will itching to drive it and test it out really bad and wont be able to! :cry:
                        1997 Camaro RS A4
                        2006 Chevy Colorado
                          Well the problem wasnt my alternator like I thoght, its something else, I dont know what, but I am taking it to a mechanic on Friday.
                          Okay, I am trying to install my WOT switch, but I cant for the life of me figure out how to set it up. Anyone have pics or suggestions, cuz I am stuck.
                          1997 Camaro RS A4
                          2006 Chevy Colorado
                            Nobody has any pics or suggestions?
                            1997 Camaro RS A4
                            2006 Chevy Colorado
                              with the kits I have setup, I just used that post on the tb that sticks out with a hole in it in front of the tb cable setup. I just found a bolt to go through it and then attach the WOT to that and bend it around so it activates. I don't have any pics right now on my pc of it though.
                              • Manimal
                                Coil springs
                                by Manimal
                                6 days ago
                              • Manimal
                                Newby here
                                by Manimal
