What would my 3.8 run if... - FirebirdV6.com/CamaroV6.com Message Board
  • What would my 3.8 run if...
    right now i run a 15.70 in a 1/4 mile i was wondering what would my E.T. be if i
    installed a 100hp Gm EFI Nitrous System, k&n intake system, and a high flow cat or jus gut the factory cats. also should i install a cat back system or just put a flowmaster muffler(i have the factory duals) headars maybe...and a high pres fuel pump
    any other sugestions?
    Re: What would my 3.8 run if...
    Slow down there bro!
    First, are you wanting to run a wet shot or dry shot? Auto tranny or 5 speed?
    You definately need a high flow fuel pump for 100 shot, either a Walbro 255lph or an inline pump from MSD. You will also need TR6 spark plugs. At least full cat-back and maybe headers too. I also reccommend a window switch.
    When you are talking drag racing other questions need to be asked such as the approx altitude of the track.
    I would venture to say at sea level cool weather, full intake/exhaust and 100 shot... maybe low 14's. You could EASILY hit high 13's probably even mid 13's with gears, stall coverter, tune, good tires and suspension. Those last few mods will help a ton!! Gotta get power to the wheels...
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      I should add that when I say gears, tune, stall, tire and suspension I am talking about:
      3.42 gears (maybe even 3.73's) with POSI
      Good professional dyno tune
      3000 stall converter
      BF Goodrich Traction TA tires
      Billstein or KYB rear suspension
      You could go a few steps farther and get 4.10 gears, drag radial tires, lower control arms and a 3800 stall. Then you would hit mid 13's no problem!!:D
      I am running an 80 wet shot, full intake/exhaust, headers, 3.42's, LSD rearend and KYB rear suspension and I am HOPING for 13.80's.
      1997 Camaro RS A4
      2006 Chevy Colorado
        100 shots on a stock motor is a little dangerour right? how many miles does your car have?
          100 shot isnt too bad as long as he upgrades his fuel system.
          1997 Camaro RS A4
          2006 Chevy Colorado
            get a wideband. start off in baby steps, say a 50, then 75.
            once u get past 75 a n20 tune is recommended, timing should be pulled for safety.
            make sure that your car is 100% mechanically sound before before playing with giggle juice.
            its a very violent pwr adder. shocks the system pretty hard.
            FWIW
              i want to run a dry shot and start at a 50hp i have a auto trans and the alt here is abought 600ft.
              What cat back system would u sugest? i was looking at a flowmaster system
              and what is a window swich?
                do a search for window switch, many diff manufa, out there. diff versions also....lots to choose from.
                  Window switch, aka RPM switch, activates the nitrous at certain RPM levels usually between 3000 and 6000. I have an NOS one that I am getting rid of if you are interested. They sell for $190 new, I'll sell it to you for $125. PM me if interested. Its nearly brand new.
                  1997 Camaro RS A4
                  2006 Chevy Colorado
