Max injectors - FirebirdV6.com/CamaroV6.com Message Board
Max injectors
  • Max injectors
    What is the max injectors size you would go on nitrous? Would 36lbs be too big or stick with 22lbs?
    2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
    Re: Max injectors
    if you are running wet you don't need to worry about injectors.
    dry kit, anything around 100 or higher you are gonna want some bigger ones. The gtp 36# is a good upgrade.
    Main thing is to see how the injectors are handling the nitrous before you upgrade them. HP tuners is great for this.
    Are you switching to nitrous after having the STS turbo? What injectors do you have with that system?
    http://www.bowtiev6.com/
      Re: Max injectors
      42.5 injectors on my STS kit
        Re: Max injectors
        what engine work again? I can't remember if you have heads/cam/intake work done or not
          Re: Max injectors
          stock engine
            Re: Max injectors
            yea they would be large, but if it is tuned for the injectors you would be fine. Just wouldn't be working them to hard at all. Definitely something you wouldn't have to worry about, lol.
            Do you have your stock injectors yet?
