Nitrous slow leak... - FirebirdV6.com/CamaroV6.com Message Board
  • Nitrous slow leak...
    I've read around the forum a bit and I've noticed that one or two will say that my slow leak is normal for a nitrous setup.
    I setup my dry nitrous system, tested out the whole deal and even shot some nitrous through the solenoid without it hooked up to my intake.
    Then I let the car sit for a few days with the valve closed....
    Today I start up the engine and it sort of hesitates and then I hear a muffled pop coming from the engine compartment :( ...
    After that, I did start the car. It idled rough for a few seconds then acted like nothing happened (no SES or CHECK ENGINE or any other lights ever came up).
    I opened the hood and could not find any sign of a backfire through the intake, although I am almost certain that is what happened.
    Does it sound like my solenoid has a leak? After all that time (72 hours or so) some nitrous leaked into the intake through the solenoid causing a small intake backfire when I started the car?
    I used gobs of teflon tape on every damned fitting, so I am guessing that the weakest links would be the bottle or solenoid construction.
    My fix for this? Well.. when I'm on my way home, I close the bottle valve and then punch the gas, giving the car the last huff of nitrous in the line. Hopefully I wont have another backfire tomorrow morning.
    I tested out my system on the road today and I am loving this dry 75 shot!! I have crossed over into the dark side and there is no turning back. I am using a .044 jet and I am thinking of going to a .048 next (something like 87-90 horses to the wheels).
    I'm thinking I'm going to put nitrous on my daily driver next (5-Speed 1.9L 1998 Saturn SL1 with 195,000 miles - gotta love GM cars).
    Re: Nitrous slow leak...
    Well first off you shouldn't leave your bottle on and be driving around. Turn it on when you plan on using it then turn it off plain and simple. Besides that using nitrous on the street is both dangerous and irresponsible, keep it on the track man! I've never noticed my solenoids leaking at all so I can't say that its normal for them to do so. You could test it with the bottle closed and the exit port of the solenoid open so you can watch it move.
    As for juicing the Saturn, I wouldn't recommend it. Unless you're trying to ruin whats already been a very reliable car at 195k. You're almost guaranteed to have issues with it after you spray a few times.
    Be safe
      Wow. It feels like I started this thread ages ago.
      I stopped using teflon tape and I only use teflon paste now.
      I do not leave the valve open. In fact it's always closed as I don't want to waste any nitrous in the lines (solenoid style bottle opener is in the mail).
      I'm not going to juice my Saturn.
      Thanks for the reply
        i know this is an old post but.. you should never NEVER use teflon tape on any nitrous fittings.!. i never had a leaking problem so i dont know what to use if you have do have one.. but ive heard from many experianced people that teflon tape is bad news. however i havent heard anything about teflon goo .any ways. just thought id put that out there....
          heh. i threw out the teflon tape a few days later after i learned that it clogs solenoids. i have TONS of paste now (but only the recommended amount on the fittings that require it)
