I'm thinking about going to the dyno soon, and was wondering since using nitrous if it would be better to dyno in 2nd gear rather then 4th gear. I know I always dynoed in 4th gear when I had it supercharged. I think it would be less stress on the motor, use less nitrous and also wouldn't get heat soaked as quick in 2nd gear. I'm on a .55 jet right now, and thinking of going to a .61 jet after I see what the .55 jet does. Would the dyno #'s be as accurate dynoing in 2nd gear? Let me Know what you think. Thanks Steve
what gear to dyno in?
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: what gear to dyno in?
sounds good , thanks08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
mine is a manual, how much would it be off if I dynoed in 2nd gear, would it read high or low numbers, I just don't want to use up all my nitrous doing a 4th gear dyno run and putting that much stress on the motor.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
u wont be using any more giggle juice spraying in 2nd or 4th.
assuming u have it on a window switch. say form 3000-6000rpms (example)
the gear ratio diff from 2nd to the actual 1:1 (4th) will gev u a false hp level reading.
hopefully somebody else will chime in on your thread that has more knowledge about the gear ratios.
in fact i dont know of any shops around here that will allow it to be juiced in a lower/quicker revving gear. at least not the ones im familiar with anyway.
you will not be the one operating the car on the dyno either. they always have an operator running it, somebody who is (supposedly. haha) trained for it proper use.
what u dont want to happen is something like this: (local shop, kid didnt setup a window switch)
http://videos.streetfire.net/hottest...1BD5FBDD33.htm
rewatch it again. listen to the rpms...they activated the juice so as soon as they hit wot it sprayed...but they were not in the 3k and above range when the went wot..sucks
EDIT: this is under the presumption that your using a wet kit. either way RESPECT THE JUICE!
peace, post up your results.Last edited by usd2sing; 09-12-2006, 06:17 PM.
Originally posted by usd2singyou will not be the one operating the car on the dyno either. they always have an operator running it, somebody who is (supposedly. haha) trained for it proper use.
I dont have a window switch hooked up, but I just ran mine up to about 3500 (and WOT) then armed it, when I got close to 5800 I turned it off. Just a little advice to those with autos and no window switch.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
I have a window switch , it is set at 3200 to 5700 rpms. The guy at the dyno shop always has me in the drivers seat, cool guy lets me get as many runs I want for $60.00. When I had the supercharger I think I had 8 runs at one dyno session.Nice video.Well see what happens, I 'll try both 2nd and 4th gear to see difference.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
yea I got to drive my own car as well. I went there with my car club and we all drove our own cars and were able to walk all around
