Just for fun, let's pretend I got a ZEX wet kit. Now being a wet kit, I would need fuel coming into the nozzle. Where would be the best place to hook a line into the fuel system for the kit? The fuel rail has schrader valve on the passenger side. Would it be advisable to remove the valve stem and connect to the fuel system there? If so, what precautions should be taken to make sure no fuel leaks at the connection during use. Oh, and anybody have a spare window switch they aren't using?
Hooking up a Zex wet kit
Re: Hooking up a Zex wet kit
Originally posted by silvachris1The fuel rail has schrader valve on the passenger side. Would it be advisable to remove the valve stem and connect to the fuel system there? If so, what precautions should be taken to make sure no fuel leaks at the connection during use. Oh, and anybody have a spare window switch they aren't using?
Just make sure the -4 AN fitting is tight so it doesnt leak. DO NOT USE ANY KIND OF THREAD SEALER ON IT! It is an AN type fitting which does not require teflon tape or paste.
I know a guy selling a window switch. I will get his contact info for you shortly.Last edited by Shodown; 09-27-2006, 05:20 PM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
I have a nitro dave digital dual window switch and is basically brand new.
I opened it but never ended up using it...its a really cool little device though.
It is a window switch setup for 1 or 2 stage nitrous (if you ever get to that)
It is a TPS switch so you wont have to mount a mechanical WOT switch
And it also has multi-gear lockout so that if you only want to spray in 2nd and 3rd or only 3rd (for whatever reasons) its ready to do that.
You can contact me on aim at FloydSummerOf68
100 bucks and you get it.Shawn<br />2002 Silver W68 Firebird
So, how does one go about removing the valve stem thingy. Just use the same tool you'd used on a tire's valve stem?~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Originally posted by silvachris1So, how does one go about removing the valve stem thingy. Just use the same tool you'd used on a tire's valve stem?
Originally posted by 97rs4lifecorrect, just make sure you relieve the pressure from the fuel system first, or you are gonna get a nice gassy bath~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Originally posted by silvachris1So whats the best way to relieve the pressure from the system? I was just gonna wrap it with a shop towel before I take it loose, but if there's a more appropriate way of doing it, I'm all for it.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Thanks guys, you've been very helpful.
Now, what about a throttle body spacer or nitrous plate? What's my best option here? I can draw it up in CAD and have it cut on a WaterJet, or should I try to drill and tap a ZZP spacer?~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Originally posted by FloydSummerOf68I have a nitro dave digital dual window switch and is basically brand new.
100 bucks and you get it.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Its a good thing you have a 99+ cuz it wouldnt work on the angled TB's like mine :(Last edited by Shodown; 09-29-2006, 06:30 PM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Originally posted by ShodownNobody makes a plate for the 3.8 :( But if you made your own or used ZZP's TP spacer, that would be kick @ss!! I would probably buy the ZZP TB spacer and drill it out.
I just don't wanna spend 85 bucks on it, if i can do it free.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Ok fellas, I need one more thing. I need a throttle position sensor output voltage wire. I need a wire that the voltage climbs when the throttle is depressed. This will act as a WOT switch. I have the electronic throttle. Help~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
I have no idea man, I dont have the elec TB on my car.
You could however, get a regular WOT switch and mount it under your pedal on the floor. Many people have had great success doing that. Thats best advice I can give though.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
