placement - FirebirdV6.com/CamaroV6.com Message Board
placement
  • placement
    I have a 94 firebird with a 3.4, I was looking to get a wet kit, but heard the nossle has to be mounted after the MAFS. If im not mistaken the MAFS is in the thottle body, so there is no room to mount the nossle. So what do I do? I need yalls help.
    3.4l 500hp to wheels <br />still dreaming
    Re: placement
    http://forum.camarov6.com/showthread.php?t=73720
    it should be just about the same on ur 3.4 as his 3.8 i belive. if not it should give u a gerneral idea. also u can buy a throttle body spacer and tap it for the nozzle.
      Re: placement
      Where would I buy a spacer at?
        Re: placement
        I dont know of anyone who makes a TB spacer for the 3.4 or 3.8 fbodies. Silvachris designed/machined his own.
        You'll have to drill/tap the TB. Look in the instructions for the nitrous kit and it should have the tap size you need.
        What kit are you looking at? I can see if I can dig some instructions for ya.
        1997 Camaro RS A4
        2006 Chevy Colorado
        2003 Kawasaki Ninja ZX6-R
          Re: placement
          It's a zex wet kit. http://www.compperformancegroupstore...uct_Code=82021
            Re: placement
            Okay, here are the instructions for that kit:
            http://www.zex.com/Base/Instructions/ZEX132.pdf
            So you shouldnt need to buy a tap, that kit already comes with the 1/8" NPT needed for installation. If you are buying the kit used, the seller may keep the tap, if they do you will need to go to a local hardware store and pick up one up.
            That looks like a pretty good kit and very easy to install.
            1997 Camaro RS A4
            2006 Chevy Colorado
