My msd window switch will cut out when the solenoids are on, after reading up on it. The solenoids pull too much for the window switch to handle and will fry the window switch in some cases. They said to wire a relay so it will not pull so much from the switch. I have it hooked up with the yellow wire for the ground from the window switch to the neg . on the soleniods. The postive for the solenoids are wired to the nitrous relay. How would I wire a relay to supply a neg. ground for the solenoids? For the 85,86,87, and 30 outputs on the relay. Thanks for your help Steve
relay for msd window switch
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: relay for msd window switch
Is there anyway you can give a diagram of what you doing?
I'll try to help you as much as possible, but it sounds a lil over my head.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
I'm trying to wire the neg leads from the soleniods to a realy which will be triggered by the neg lead from the msd window switch. If it is possible?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I think I found out how to wire it up correctly, I have to use another relay seperate from the nitrous relay for the solenoids. This is the relay wiring for the msd switch, 30,85 go to postive source( i"ll use the relay from the nitrous kit). Solenoids are grounded and the other wire goes to 87 pin, 86 pin is the yellow wire from the msd window switch(gray wire not used). I'll see if it works on Wed.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
