Maybe Time To Up Nitrous Shot? - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: Maybe Time To Up Nitrous Shot?
    Originally posted by factoryfreak v6 firebird
    ill just do that... hey shodown maybe u can answer this. i wanted 4.10 gears and a lsd of course but when i looked up for the new one's it showed that the slp gears needed a paddle kit of some sort u know why. ill prob just get some newer gm gears so i dont have to break them in ya know.
    What kind of differential do you have?
    I ordered a Zexel Torsen off ebay and the idiot didnt throw in the paddle kit which IS SUPPOSED to come with the ZT. So it was just another $20 for a paddle kit.
    BUT!!!!!
    THIS SHOULD BE STICKIED IN THE GEARS SECTION:
    I think, (NO, I KNOW) you are saying that WITH 4.10s (or bigger) you will need the SPECIAL SLP paddle kit because the ring gear on the 4.10s will NOT allow the stock paddle kit to fit in!!! I Would know! The SLP is like $170++
    I had to get a bench grinder and grind the **** out of the stock paddle kit in order to make it fit, but hey, I saved $170.
    Yes, spraying at low rpms is dangerous... But doesnt Nitrous LIKE high rpms anyways??? So whats the point of spraying at so low rpms where you are not making much power anyways?????
    • #32
      i was thinking ... either zexel torsen, or eaton.. w/e one's cheaper and available here in the next couple of weeks. but i thought i would need the paddle kit.
      help me get in those higher rpms faster .. every lil bit helps althought i am going to start using the nitrous at 3k and above. i figured i would ask him since me and him were talkin and could get answer pretty quickly. but thanks slow6.
      • #33
        to answer the topic question...
        oh, it is Always time to up the nitrous shot ;)
        • #34
          Reading ur mods i didnt see a stall so how in the hell do you launch at 2500rpms, and spray of the line??
          '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
          '99 Firebird SOLD 1/4 mile 15.4 @ 86
          '66 Ford SOLD
          • #35
            manual doesn't need a stall
            http://www.bowtiev6.com/
            • #36
              i have a a4.i rev until it catches which is about 2000 rpms in my car and right when my car gets traction which is almost instantly i used the nitrous thats why i said 2500-3000. i have before used it right when i launched it but that was right when i the dr's.
              • #37
                IF you are on the stock tune and you are spraying during closed loop and NOT in PE... well, your engine is gonna blow up!!
                Btw, I love it when someone says "you're gonna blow you're $hit up!!!" thats hilarious! and we can only hope!
                • #38
                  Here is the stock PE Hot table:
                  50.00000 50.00000 54.00391 64.00391 71.50391 75.99609 78.49609 79.49219 80.00000 80.00000 80.00000 80.00000 80.00000 80.00000 80.00000 80.00000 80.00000
                  So you are not gonna go into PE Mode until you reach at least 50% TPS
                  So I guess just dont spray until after 50% TPS
                  (Throttle Position Sensor)
                  The stock PE table is rich, in order to be safe
                  • #39
                    thanks slow6 i have decided to start waiting after 3k to turn it on instead.
                    • #40
                      Some people (with a bit more boost than you, like 10-12psi) are going into PE mode as low as from 20% - 35% (2800-3000rpms)
                      And their AFR is alot richer I think, like 11.3:1 - 11.7:1
                      And they have less timing!
                      I'm sure they use higher octane fuel as well
                      Just something to think about..
                      • #41
                        ...i dont mess my engine up. i have a a4. i will be getting a bigger ...
                        '66 Ford SOLD
                        • #42
                          yea didn't know who was being talked too, lol. auto it isn't possible without stall
                          • #43
                            oh, sorry
                            '66 Ford SOLD
                            • #44
                              You will only need the paddle kit for a zexel LSD.
                              For the eaton you can put whatever gear you want in it.
                              If you want a new fuel pump I'm selling direct replacement walbro pumps that work like stock and flow 255lph (not the BS walbro pumps from ZZP or TSP that run your tank dry when you stll have 4 gallons left) for 129.99 right now (only have 3 left)
                              Shawn<br />2002 Silver W68 Firebird
                              • #45
                                If you want more.... try a 100 shot first.
