Thinking about jumping to the next step... - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: Thinking about jumping to the next step...
    what is the MSD RPM switch and what does it cost?
    1997 30th Anniversary Camaro.
    SLP CAI, Dynomax, PCM tune, SS Hood, Clear Corners, T-Tops, Sony Xplod
    TEAM RED
    • #32
      its a window switch where you set the RPMS to spray in
      http://www.bowtiev6.com/
      • #33
        It allows you to spray between certain RPM ranges, usually 3000-6000. The RPM's can be adjusted by simply changing out the pills.
        They cost about $85.
        1997 Camaro RS A4
        2006 Chevy Colorado
        2003 Kawasaki Ninja ZX6-R
        • #34
          Do yourself a favor and spend another 20 bucks and get a digital switch so you dont have to buy pills when you want different RPMs.
          Shawn<br />2002 Silver W68 Firebird
          • #35
            Ok so this may sound like a total idiot thing to ask but, would anyone mind taking me through making a run while using nitrous. What I mean is, give me the order of how things are "switched on" and then shut down after the run is over. I am really trying to learn as much as I can about this stuff, and the only idea I have of NOS is what I have seen on Fast and the Furious.......not to scare the hell out of anyone or anything!! Please Teach me! :bowdown:
            TEAM RED
            • #36
              launch, get to 3k rpms, flip activation switch, hold on, cross line, turn off activation switch, release gas, brake, turn off of track, get slip, go back to staging lanes, and repeat
              • #37
                lol, thanks for making it so simple, that is where I was getting so confused, is where I suppose you line up, turn the bottle open, take off to 3000+ in (FIRST OR SECOND), flip the "arm" switch and it takes off, then just simply flip it back off and close the bottle.
                And if I am spraying in first at 3000+ what happend when it shifts into 2nd and then drops the RPMS agian?
                TEAM RED
                • #38
                  if you are going WOT you won't drop below 3k rpms. I spray right through the gear shifts in my automatic
                  • #39
                    ok thats cool, just want to make sure im getting the right idea!
                    TEAM RED
                    • #40
                      In my car, I just push the pedal all the way to the floor and the system does everthing else :D
                      1997 Camaro RS A4
                      2006 Chevy Colorado
                      • #41
                        now what do you have that lets you do that?
                        TEAM RED
                        • #42
                          97rs4life- I like how you have your switches set up in your dash. What do each of the switches do? I think I saw two flip switchs and one push button. Looks awesome, and will probably go with something like that. I was just curious what each switch did?
                          TEAM RED
                          • #43
                            Well, I do have to flip 2 toggle swithes: one to arm the system itself and the other is to open my bottle (remote bottle opener FTW ;)) but other than that, its all electronically controlled via my NOS window switch (3000-6000 RPM).
                            1997 Camaro RS A4
                            2006 Chevy Colorado
                            • #44
                              My switches are similar to 97rs4life (I copied him cuz he's cool like that :))
                              From left to right bottle opener, bottle heater, N2O arm, purge
                              I painted the area around the first switch (bottle opener) black so you cant see the glue anymore. The plate is just a switch plate from a convertable that I drilled 2 more holes into. For the purge button I just removed the cig lighter.
                              1997 Camaro RS A4
                              2006 Chevy Colorado
                              • #45
                                so can the purge be a toggle switch to, or does it have to be a push button. I mean I'd rather use the push button but Im just curious
                                TEAM RED
