Thinking about jumping to the next step... - FirebirdV6.com/CamaroV6.com Message Board
  • #46
    Re: Thinking about jumping to the next step...
    You could use a toggle, but you have more control over it with a push button.
    BTW, you have a PM.
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
    • #47
      Thats awesome man, thanks for that, it will be helpful!
      1997 30th Anniversary Camaro.
      SLP CAI, Dynomax, PCM tune, SS Hood, Clear Corners, T-Tops, Sony Xplod
      TEAM RED
      • #48
        My switches are:
        Activation switch (flip)----Heater (flip)-----Purge (push button)
        I got the panel for like 5 bucks from a guy parting out a car and then just cut the holes. Convertables, and cars with TCS have the panel. I originally had a cubby hole there
        http://www.bowtiev6.com/
        • #49
          awesome, thanks man
          TEAM RED
          • #50
            wow thoes vids were really helpful, shodown. Thanks a bunch!
            TEAM RED
            • #51
              I havent watched them all yet, when I do, I will see if James will make them a sticky. But first I want to watch them all the way thru before I tell anyone that they are even worth watching. :)
              1997 Camaro RS A4
              2006 Chevy Colorado
              • #52
                well the ones I watched will deff. be coming back out as I am installing this baby. It has such a nice step by step guide to it. Thanks again for giving me thoes!
                TEAM RED
                • #53
                  Next question: :) Sorry guys
                  I went out and pulled the cover off the 'maro this morning and took a good look at everything. I found the valve to attach the fuel line to, but instead of being on the end of the line like you showed me "shodown" it was on top of the line, in the middle. Is that the right valve? I can take a pick if you'd like.
                  TEAM RED
                  • #54
                    oh ****, never mind that question, I took a look at the pics again, and realized that it is the right one, sorry! :)
                    TEAM RED
                    • #55
                      Thoes of you that have a purge, where did you route your purge line to to get out of the engine bay? I know most of you are around the window, but Im trying to figure out how to get it out without pinching it in the hood. Please help.
                      TEAM RED
                      • #56
                        my purge is split and goes to each foglight so the foglight lights up the purge at night. You can also run it up by the windshield and just got a hole in the cowl/plastic piece and mount it up there.
                        • #57
                          I drilled 2 small holes in my cowl and ran it out that way.
                          1997 Camaro RS A4
                          2006 Chevy Colorado
                          • #58
                            I wouldnt waste my money on a purge until you've gotten everything else taken care of.
                            I still dont use a purge and dont plan on adding one anytime soon and I'm doing just fine :P
                            Sure, it gives you a little bit colder charge, but that isnt what you are going to be concerned with yet.
                            Shawn<br />2002 Silver W68 Firebird
                            • #59
                              mine is actually coming with a purge, that is why I ask
                              TEAM RED
                              • #60
                                A good purge will also help keep a consistent A/F ratio. If you spray warm, gaseous nitrous with the same mix of fuel, it will go pretty rich. I know its only for a small amount of time, but its something to consider.
                                Floyd has a good point though, get the necessities first then accessories. But if your kit comes with a purge, then you are all set :tup:
                                1997 Camaro RS A4
                                2006 Chevy Colorado
