Thinking about jumping to the next step... - FirebirdV6.com/CamaroV6.com Message Board
  • #76
    Re: Thinking about jumping to the next step...
    What I am probly going to do is go to the place where I can get it filled and ask them if they have a problem with the sticker not being on there. Just to make sure!
    1997 30th Anniversary Camaro.
    SLP CAI, Dynomax, PCM tune, SS Hood, Clear Corners, T-Tops, Sony Xplod
    TEAM RED
    • #77
      You could just take the label off, paint/powdercoat it then just buy another label to put back on it. You can buy them from almost any nitrous distributer such Summit, Jegs, Dynotune, HSW etc.
      Thats what I'd do. Just my .02 :)
      1997 Camaro RS A4
      2006 Chevy Colorado
      2003 Kawasaki Ninja ZX6-R
      • #78
        not that hard to just tape it up so that it doesn't get painted, instead of buying a new one
        http://www.bowtiev6.com/
        • #79
          I'd be afraid that it would peel around the label though.
          1997 Camaro RS A4
          2006 Chevy Colorado
          • #80
            That sounds like a good idea, ill probly do just that!
            TEAM RED
            • #81
              Does anyone know where the throttle position sensor is located at on a 97 camaro? I have to run a white wire from my NMU to the throttle position sensor, and I am concerned that I might not have one. It is for the WOT switch that is built in with the zex kit. thanks!
              TEAM RED
              • #82
                actually nevermind, I just found a good diagram that pointed out exactly where it is located, however, if anyone has a pic of the wire connected to the TPS on a 97 that would be awesome...thanks!
                TEAM RED
                • #83
                  Nobody typically uses a TPS switch with the pre 98 fbodies because we have throttle cables and can use a simple WOT switch that is triggered by the throttle cable position.
                  1997 Camaro RS A4
                  2006 Chevy Colorado
                  • #84
                    So, just how "safe" is adding a hundred shot to a stock engine with 75K miles on it?
                    Lounge Moderator
                    • #85
                      Not bad at all. With the supporting mods, tune and when used correctly it will be just fine.
                      BTW, the search button is your friend ;)
                      1997 Camaro RS A4
                      2006 Chevy Colorado
                      • #86
                        where can I get one for a 97 and what usually does it cost and are you saying then just tape up the white wire and do not use it? I would really like to use the built in TPS if at all possible.
                        TEAM RED
                        • #87
                          The TPS sensor is on the Pass side of the tb. You can tap into the tps wire on the sensor instead of buying another item.
                          • #88
                            what color wire is it? I think there is 3 wires?
                            TEAM RED
                            • #89
                              Dark blue if I remember correctly. What colors are there on it?
                              • #90
                                Im not sure, im in class right now, but I will check tonight when I get home and post up to let you know what the colors are!
                                TEAM RED
