Does anyone wanna help me install nitrous - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Does anyone wanna help me install nitrous
    BodDole has a dry kit on his and its in the right position on the whisper lid. check it out here: http://forum.camarov6.com/showthread...hlight=dry+kit (yes thats on his new LS1, but its the same placement for our cars)
    BTW, dont burn a hole in it, DRILL IT.....
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
    • #17
      okay I can't take a picture but this is the exact same kit that I am in the process of installing http://cgi.ebay.com/ebaymotors/LS1-D...ayphotohosting
      • #18
        this guy has my exact kit now I know where to burn the hole on the whisper lid http://www.cardomain.com/ride/2445423/2
        • #19
          whats so wrong about burning a hole in it with a small wire torch that I used to heat up the wires with. I guess I want use the torch then yall are the pros Im just learning and reading everything about nitrous that I can.
          I have a question I haven't been able to get both of the straps down on my whisper lid but it still closes but since Im gonna be spraying my engine I gotta figure out a way to get both of the straps to stay down I would hate for the whole complete lid to come off while spraying if you know what I mean
          • #20
            just drill it, more accurate then trying to burn a hole. Drilling it will not hurt it at all. Tape around the space you are drilling if worried.
            If you want to have a really good dry setup, run dual nozzles, and that way the spray will be spread out over it all accurately. Many people run one nozzle just fine though.
            Yea you have the 70* nozzle then, put it like the image below. You want it to be in the path of the air going in
            http://www.bowtiev6.com/
            • #21
              just wondering have anybody used anything other than bottle heater or a torch to heat up thier bottle because I found this but don't know if it will work it kinda resembles the bottle heater http://cgi.ebay.com/Chromalox-Silico...QQcmdZViewItem
              Also there is heater blankets also but I don't know if they get hot enough though
              • #22
                use a bottle heater made for nitrous, safe and effective, stay away from the torch method.
                Or a hot summer day, lol
                Don't try and cut corners with nitrous, you will end up paying for it in the end
                • #23
                  You are really stuck on this torch thing huh? LOL.
                  1997 Camaro RS A4
                  2006 Chevy Colorado
                  • #24
                    Okay I ran into a couple problems here is the first one I can't figure out where to run the feed line from my spare tire area without it touching any moving part or either touching the exhaust. I don't have a jack so I have to lay on my back and run the feed line from the spare tire area Some pictures would be nice so I can get an idea.
                    Another problem is I can't figure out where to mount the wot switch and where in the heck is the throttle switch so I can mount the wot switch I looked everywhere in the engine bay and still can't see it. I have a 98 camaro btw
                    I know some people mount thiers on the pedal but I don't wanna do that
                    • #25
                      To secure the feedline you can drill some holes (not with torch lol) in the subfame and use wire ties to hold it. Thats what I did.
                      Here are some pics of my WOT switch(es). I have 2 for my dual stage but you only have 1.
                      You will probably have to bend the bracket a lil bit to get it to fit properly.
                      1997 Camaro RS A4
                      2006 Chevy Colorado
                      • #26
                        good joke on the torch thanks doing it now. I am now in the process of putting in the toggle switches this is how I did it. I put them where the radio bezel is I just pushed the little thing that says camaro on the bezel and it poped out and there was two holes ready for my toggle switches.
                        In case you don't know what Im talking about its the camaro sign next to the fog light switches and the sgs switches the sign pops right out.
                        I just gotta figure out a way to get these wires to go from the radio bezel to inside the engine where the wot switch is do you have any idea on how I run the wires from the stereo area to the engine
                        • #27
                          I know what you are talking about....
                          I drilled a rather large hole in my firewall behind the pedals to get my wires thru. I have about 8976784 wires going thru it
                          1997 Camaro RS A4
                          2006 Chevy Colorado
                          • #28
                            Here are some pics of my firewall:
                            1997 Camaro RS A4
                            2006 Chevy Colorado
                            • #29
                              yeah but you could have kept the fog lights and just poped out the camaro sign and its two holes thier if you need it.
                              I really appeciate all the help and still need more help
                              • #30
                                I dont use my fog lights anyhow, thats why I took out that switch and replaced it with my line lock toggle. I know I could have taken out the CAMARO thing, but I chose not too. :)
                                1997 Camaro RS A4
                                2006 Chevy Colorado
                                • Manimal
                                  Coil springs
                                  by Manimal
                                  6 days ago
                                • Manimal
                                  Newby here
                                  by Manimal
