hey i'm going to tap my tb this week. for the nitrous express kit, what size tap. looks like a 5/16's
tap
Re: tap
hmm, do you have your instructions yet? Should be in the instructions what size the tap is. Otherwise maybe check their website for pdf file of instructions.
I cannot remember the size, I just took my bits and found the one that fit the coupling and called it good, lol.
Do you have the two piece coupling to hold it in place in the tb?
Re: tap
The NX kit is going to be a 9/16 refer to here- http://www.nitrousexpress.com/Instructions/stage1.pdf
Re: tap
oh, i tapped mine 9/16ths because i used those two nuts that screw onto the shark nozzle. but 9/16ths is pretty big, the only reason i had one is because my dad is an electrician and he had one. this is my tap:
Re: tap
yea I used the two nut grommet for mine, I wanted to make sure it stayed in correctly and didn't move or anything. I would use the grommet if you have it. You can tap it, but it isn't that thick of a wall
Re: tap
my not measure the thread pitch? there is a tool that comes in a tap set that will tell you what you need exactly.1998 Camaro Z28 M6 lets just say it breathes easy <br />*RedLineVSix*<br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">www.redlinevsix.com</a><br />1993 Camaro A4 16.67 1/4 SOLD
