Think it can handle this? Keep in mind I have a nitrous cam that added about 40 horses n/a. Reason is with the kit I have 3 jets to choose, I want to get 50/75/100 and run the 50 until I upgrade injectors. But if they are going to be maxed on the 50 I'll go ahead and get 35/50/75.
50 shot dry on stock injectors?
Re: 50 shot dry on stock injectors?
should be alright, but I would get a scanner on there and check your injector duty cycle and see where you are at
i know i dont know much, but i hear alot of people doing 75/100 shots with just a spark plug change, why you going lower?1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Originally posted by mestupryani know i dont know much, but i hear alot of people doing 75/100 shots with just a spark plug change, why you going lower?sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Originally posted by airattack111Think it can handle this? Keep in mind I have a nitrous cam that added about 40 horses n/a. Reason is with the kit I have 3 jets to choose, I want to get 50/75/100 and run the 50 until I upgrade injectors. But if they are going to be maxed on the 50 I'll go ahead and get 35/50/75.
Again if that's your options I'd go with the 50 to start and log everything, but best practice would be start with a N/A run log it see what your injectors are doing, spray a small shot maybe 30-35 to see how they react and move up from there. It is more expensive in the short term, but can detect a problem before it becomes a BIG problem later on.
