Do any of you guys have an inline pump set up for your nitrous? I came up on an MSD inline pump a while back and have yet to get around to installing it. Ive been squeezing a 75 shot for a long time with plans to go for the 100 shot to really see what the 3.4 can hold. I just wanted to know if anyone else out there has one specifically for their nitrous? And also I was curious, doesnt an inline pump over work your in-tank pump since it pumps out higher psi?
In line fuel pump
Re: In line fuel pump
Already have tr6's amoung a variety of other things... Im trying to avoid going with an in tank pump, as I already have this in-line pump. I just want to add it as insurance to my existing system to keep up fuel psi when I am spraying as much as a 100 shot...Last edited by mlsFiT; 07-15-2007, 11:19 AM.
how often are you spraying? Inlines are fine for the occasional sprayer, and there have been quite a few guys in the past that have used the inline with nitrous and just had a switch to turn it on when they were going to spray. Most people nowadays use the intanks though since they are only 125 bucks and not to bad to install.
Just make sure you remember to turn the pump on everytime you are spraying, so you don't run lean or anything and blow it
I only spray 5-6 times a month. I had even been thinking about wiring it to the system to come on with the n2o... In the future I will swap the in-tank, but i want to use the in-line for now since I already have it... thanks for the info
problem with wiring it with the kit, is that there is going to be a second of delay wiring the pump is turning on as the nitrous is getting shot, so you might be lean for a split second till the pump is completely fired up.
just a theory I was thinking about with those inlines and running them on the same switch. I could be wrong
dynotune makes great stuff for a great price, one of the better brands out there.
