Set-up Questions - FirebirdV6.com/CamaroV6.com Message Board
Set-up Questions
  • Set-up Questions
    Just bought a used nitrous system. Has all the plumbing and such, just needs wiring. I'm trying to set-up a safe install, and was wondering which route you guys think I should go.
    1- Standard WOT switch with MSD digital window switch
    2-Electronic WOT switch with MSD Digital Window Switch
    3- Digital TPS and Window switch
    I'm liking the 3rd set-up since it has gear lock out. I'm also buying a nitrous filter, FPSS, LED arming switch, and momentary purge switch to go with this. Would 20psi be a decent FPSS setting for our cars?
    This is all going on a 97 3.8 M5 Camaro w/ 92K, full exhaust, intake, and 3.73 LSD rear. About to do a plug change to TR6's, new wires, oil change, and tranny fluid change.
    7
    1
    28.57%
    2
    2
    14.29%
    1
    3
    57.14%
    4
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Set-up Questions
    is the third option the dynotune WOT/window switch setup?
    You will be good with any of those setups, the standard WOT switch is easy to setup on our 97s. I had one to start out, I now have that dynotune 2stage window switch for mine with the gear lockout as I am running two stages.
    http://www.bowtiev6.com/
      I voted #1 b/c thats the setup I have and it works perfectly on my car. :)
      1997 Camaro RS A4
      2006 Chevy Colorado
      2003 Kawasaki Ninja ZX6-R
        i would say #3
        TPP?
        (trick performance parts)
        2002 SOM Camaro- Sold
        2006 S60- Sold
        2000 Cherokee- The desert whip
          Well, I was thinking set-up 3 because 1- gear lock out, 2- everything's in one unit. The kit I bought is a dual stage set-up, however I plan on running just the wet stage for right now, so 3- I may up to a 2nd stage in the future. Just checking with you guys. Does anyone have any recommendations for other set-ups?
          EDIT: Also, what relays are you guys using for your set-ups? I'm going to make a diagram of the wiring tomorrow, and am wondering which relay, what size, etc.
          EDIT 2: Been doing some more research, and dual stage is really starting to look nice. I'm looking into a 50 or 75 dry shot off the line, then a 75 wet kicking in at 3K in 2nd gear. With that, I'm sure I'll be needing some DRs :D
          ~97 3.8L V6 Camaro~
          A few things
            OK, I found a window switch for pretty cheap. But, it doesn't have the 1st gear lockout. I think I can rigg something up to keep it from spraying in 1st gear, but any suggestions? I was thinking a normally closed momentay push button mounted on the console that would be pushed when I have the shifter in 1st gear position. Haven't looked at this, just what I came up with in the last 30 seconds. Any suggestions for a homemade 1st gear lock out?
            ~97 3.8L V6 Camaro~
            A few things
