timing - FirebirdV6.com/CamaroV6.com Message Board
timing
  • timing
    If I install a 75 dry shot on my 3.4 will I have to pull any timing, if so how much?
    3.4l 500hp to wheels <br />still dreaming
    Re: timing
    nope, but start out at a 50 shot and see how it reacts to the nitrous. Each car can be different. Plus how do you plan on pulling timing from a 3.4?
    http://www.bowtiev6.com/
      Re: timing
      No need to pull timing. Just make sure you run 93+ octane. Fresh plugs, wires, fuel filter.
        Re: timing
        Will start with a 50shot, for the timing I thought you could use a msd dis4 ignition, and how much whp do you think a full bolt-on 3.4 make with a 50 and a 75 shot?
          Re: timing
          180-210 whp on the bottle depending on the car, nitrous pressure, nozzle placement, weather, dyno condition, etc. Way to many things affect it.
            Re: timing
            I wouldn't use a DIS-4. My personal experiance is that they are more trouble than they are worth on our cars. Just throw in a fresh set of NGK TR-6 plugs and keep good gas in the car.
