Working on wiring the system up right now. The 54 pin on the PCM is the one with the blue wire coming out, right? I just tapped into that wire, that should work fine for my tach input, right? Trying to find a way to test it out right now, but I can't seem to find any light bulbs or anything to hook up to the relay, and my brother claims he can't hear the solenoid over the engine.
Wiring
Re: Wiring
Someone plz help me. I'm tired of messin aroung with this thing. My pin 54 is blue, not white. I don't even have a white wire goin to my PCM, I have a grey one, but no white (I tried washing it to make sure it wasn't dirty, and it is indeed grey). I don't really want to use the cam sensor cuz then I'll have wires hanging down by all the pulleys and such. And if the wire coming from my pin 54 is blue, then should I be looking for a blue wire, or white one?~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Wiring
OMG, I feel so stupid. It generally helps to have power going to the window switch in order for it to work:o . Blue wire works just fine for me, my relay's a clickin :D. Got school tomorrow, but afterwards I'm hoping to route the lines, get my jets and get her filled! I'm certain I'll have spray by Fri, so I can get some times then:) Only with a 50 shot though :(~97 3.8L V6 Camaro~
A few things
