NO nitrous back fires!!! - FirebirdV6.com/CamaroV6.com Message Board
  • NO nitrous back fires!!!
    went to the dyno. she must be all better cause she was lovin her nitrous again. and yes i went up to a 125 shot!!! here is the link
    http://forum.camarov6.com/showthread.php?t=83679
    WAWA-A-HOLIC
    Re: NO nitrous back fires!!!
    What changed about your intake setup and why?
      Glad to hear it! :tup:
      1997 Camaro RS A4
      2006 Chevy Colorado
      2003 Kawasaki Ninja ZX6-R
        opps sorry, i forgot i posted in here lol.
        well i think the main problem was the fuel pressure reg. that ended up going on me all together a month after the back fires.
        but i had a spark issure(don't know if that happened after the first backfire)
        i was spraying before maf(never had a problem with the pre. 2 years)
        so it could have been a number of things. all that matters is that good now
        and since friday i have gone threw a whole bottle of nitrous lol. it been like 70 deg out and i can't help myself
        ***edit***
        i'm going to the track tomorrow
        WAWA-A-HOLIC
          You running an MSD box in your car by any chance?
          2004 CE Corvette 10.86@132mph
          2011 Cadillac CTS-V
          2006 Mitsubishi Eclipse GS
            box??
            WAWA-A-HOLIC
              Originally posted by kristen
              box??
              FirebirdV6.com/CamaroV6.com Administrator
              Stupid is rewarded with the ban button.
              Official Avatar Nazi according to Meatyshells :D
                haha... yeah, ignition box. Multiple Spark Discharge high voltage coil..
                2011 Cadillac CTS-V
                  nope!
                  WAWA-A-HOLIC
                    We cant run an MSD ignition box since we have coil packs instead of a distrubuter.
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                      You can't run a DIS-4??? WTF.. you got a special motor?
                        DIS4 is not an ignition box such as the 6AL ignition box that makes the ignition run a hotter/higher spark as Shirl was referring to. The DIS4 is band-aid to tuning for retarding/advancing timing, nothing more.
                        1997 Camaro RS A4
                        2006 Chevy Colorado
                          Ok.. maybe I'm missing something..
                          http://www.msdignition.com/sci_4.htm
                          Spark Energy: 105 - 115 milliJoules per spark
                          Primary Voltage: 460 - 480 Volts Delivered to Coil
                          Output Voltage: 40,000 + Volts
                          Spark Series Duration: 20° Crankshaft Rotation
                          Operating Voltage: 12 - 18 volts, neg. ground
                          Current Draw: 7.4 amp @ 10,000 rpm
                          RPM Range: 14,000 rpm with 14.4 volt supply
                          Seems to be more than stock to me....
                            Ding Ding Ding!! :)
                            2011 Cadillac CTS-V
                              Ok.. specs look similar:
                              6AL http://www.msdignition.com/ignition_6_6420.htm
                              Operating Voltage: +10-18 VDC Negative Ground
                              Current Requirements: 5 Amps-5,000 RPM
                              10 Amps-10,000 RPM
                              RPM Range: 15,000 RPM with 14.4 Volts
                              Spark Duration: 20° Crankshaft Rotation
                              Energy Output Max: 105-115 mJ Per Spark
                              Weight and Size: 3 lbs, 8"Lx4"Wx2.25"H
                              Voltage Output Max: Primary: 460-480 Volts
                              Secondary: 45,000 Volts (Blaster Coil)
                              Want to clarify for me since this makes no sense what your saying....
